How Does Heat Transfer Into a Sphere Over Time?
The discussion focuses on simulating heat flux into a sphere and a cylinder using user-friendly software. The goal is to model how heat transfers from an external temperature of 50°C into a sphere initially at 20°C, tracking the progression over time and determining when steady state is reached. Additionally, the user wants to compare this with a cylindrical slice of the same radius to observe differences in heat transfer rates. Suggestions for suitable software packages with a graphical user interface and minimal learning curve are requested. Understanding the transient heat conduction equation in spherical coordinates is also mentioned as potentially relevant to the simulation.
strokebow
Hi,
I am looking to simulate a very - seemingly - simple case.
Any advice on a software package would be helpful - preferably gui which doesn't have a steep learning curve.
I want to model the heat flux into a sphere from the outside. The dimensions of the sphere are not important to me. I want to see how heat flow progresses into the sphere from the outside. For example, if the sphere was at temperature of 20 degs c. Then if the the outside temperature was 50 degs c, I would like to show how the heat transfers into the sphere over a given time period. Moreover, I would like to find out the point at which steady state is occurred.
I would then like to contrast that to the case of a cylinder (same radius as the sphere) but with a very short length. I.E. so that it approximates taking a slice through that sphere. I want to apply the same test to this circular slice, to show how the heat transfer takes a shorter time to reach steady state.
Any thoughts/suggestions are most welcome?
Science news on Phys.org
strokebow said:
Hi,
Are you familiar with the transient heat conduction equation in spherical coordinates?
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
