edorion
- 3
- 1
- TL;DR Summary
- Need help sizing a heater for a particular application.
I am trying to determine the size of a single cartridge heater or 2 cartridge heaters to heat a large mass of aluminum to 400F. The aluminum block will be sitting inside an insulated (all sides) enclosure. The following are the specs for this problem.
- Max surface temp of aluminum block is 400F
- Aluminum block is 3.25in tall solid cylinder with 5in DIA
- All surfaces of block are exposed to air (inside enclosure)
- Insulated enclosure is cylindrical shape with ID of 9in and OD of 12in with top and bottom covered (essentially 1.5in of insulation all around)
- Insulation is aerogel with thermal conductivity of 0.0116 BTU/(ft*h*F)
- Outside ambient temp can get as low as 0F
- Heaters must be DC, ideally 12V
- Heaters will be snug fit into aluminum block with thermal paste on all sides
What is the wattage of heater required if I use 2?
