Heating water at 100 °C without coolers?
  • Thread starter Thread starter k_amy21
    Heating Water
Exposing metallic materials to water at 100 °C for extended periods raises concerns about safety and equipment setup. The discussion emphasizes the importance of not sealing glass vessels tightly without a safety valve due to potential overpressure risks, especially if the thermostat fails. A suggestion is made to use a double boiler method to mitigate overpressure concerns while allowing for safe sealing of the vessels. Additionally, there are worries about the potential for implosion during a blackout. The user expresses frustration over the need for coolers, as they complicate the setup and fit within the oven, leading to a preference for simpler heating methods despite lacking the necessary equipment like heating mantles and temperature regulators.
k_amy21
hi,
I need to expose metallic material in the WATER for a certain period of time (3, 6 and 12 months) at 100 °C (+/- 5 °C) and normal pressure. Is it possible to do that without using coolers?
I was thinking of putting the glass vessels in the oven and closing it with some "special" equipment (please, see the attached file). What do you think, would that be safe and secure so the water does not evaporate and the whole system doesn´t explode because of the overpressure??
Regards
Chemistry news on Phys.org
I would not close it tight without a safety valve, you need to take into account possible failure of the thermostat. That is assuming in the first place the vessel you are using is capable of sustaining slight overpressure.
Note that in the case of the blackout you may have quite the opposite problem - implosion instead of explosion.
Make a double boiler by immersing the glass vessels in boiling water. You could then go ahead and seal the glass vessels tight without concern for overpressure. Just be sure the boiler doesn't run dry.
I think this metal part around the vessel is preety secure (like some kind of valve), but these red plastic things which are holding the top I-don´t-know-what´s-it-cold :smile: could loosen after a while.
I am just searching for the easiest way to set up my experiment and it will, obviously, be using the coolers. grrrrrr... It´s not because I need to use the coolers, but it´s because then the whole equipment doesn´t fit in the oven, and therefore I need to use heating mantles and temperature regulators which I don´t have enough! ..gosh.. :cry:
It seems like a simple enough question: what is the solubility of epsom salt in water at 20°C? A graph or table showing how it varies with temperature would be a bonus. But upon searching the internet I have been unable to determine this with confidence. Wikipedia gives the value of 113g/100ml. But other sources disagree and I can't find a definitive source for the information. I even asked chatgpt but it couldn't be sure either. I thought, naively, that this would be easy to look up without...
I was introduced to the Octet Rule recently and make me wonder, why does 8 valence electrons or a full p orbital always make an element inert? What is so special with a full p orbital? Like take Calcium for an example, its outer orbital is filled but its only the s orbital thats filled so its still reactive not so much as the Alkaline metals but still pretty reactive. Can someone explain it to me? Thanks!!
