Why Use Nitric Acid for Heavy Metal Digestion?
The discussion focuses on the use of nitric acid for the digestion of water samples in the detection of heavy metals like copper and lead through atomic absorption spectroscopy (AAS). The original poster questions why nitric acid is preferred over other acids for this process, suggesting that the choice may depend on the specific heavy metal being analyzed. However, responses clarify that nitric acid is favored because it effectively dissolves metals without forming insoluble sulfates or volatile chlorides. Additionally, there is a correction regarding terminology, emphasizing that AAS relies on the atomization of the analyte rather than its absorption. This highlights the importance of precise language in scientific discussions.
Henokh96
I already done an experiment for detecting the presence of heavy metals(copper and lead) .
The last step for detection is through the absorption of analyte by atomic absorption spectroscopy.
Before that step to be done, the first process is to digest the water sample in the fume chamber.
And my question is that why on Earth are we using nitric acid for the digestion? Why not use the other types of acid?
If I am right , the reason why depends the type of heavy metal that we wanted to achieve .
Tell me if I am wrong :) tq
Chemistry news on Phys.org
You are wrong.
Likes Henokh96
OK, more seriously - sulfates tend to be insoluble, chlorides tend to be volatile.
Watch your language. This:
is wrong. AAS is not based on the "absorption of analyte".
Borek said:
You are wrong.
Further explanation might help sir
Atomized analyte correct?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
