Solving Heavy ODE System to Compute Round Jet Near Field
In summary, Daniel is trying to solve a system of three first order ordinary differential equations in order to solve the near field description of a round jet. He has done this before with Blasius type equations, but the density makes it a bit difficult. He is asking for help from Clausius, who is familiar with the application. Clausius tells Daniel that rho is a function of Y, that is \rho=g(Y(\eta)) and that this function is known. He then reduces the problem to five first order ODEs and attempts to solve them by a Runge-Kutta/Shooting Method. However, he has trouble setting up the process and would appreciate examples of problems solved using this
Clausius2
In order to solve the near field description of a round jet, I want to work out the variables [tex] F(\eta) [/tex], [tex] \rho(\eta) [/tex] and [tex] Y(\eta) [/tex] which represents the self similar stream function, density, and mass fraction respectively. The system obtained is:
[tex] \Big(\frac{F'}{\rho}\Big)''+\frac{F}{2}\Big(\frac{F'}{\rho}\Big)'=0 [/tex] (1)
[tex] (\rho Y')'+\frac{F}{2}Y'=0 [/tex] (2)
besides a function [tex]\rho=\rho(Y)[/tex] which is known previously.
Boundary conditions are:
1) [tex] \eta\rightarrow+\infty[/tex]; [tex] \frac{F'}{\rho}\rightarrow 0[/tex]; [tex] Y \rightarrow 0[/tex];
2) [tex] \eta\rightarrow-\infty[/tex]; [tex] \frac{F'}{\rho}\rightarrow 1[/tex]; [tex] Y \rightarrow 1[/tex]; [tex] F\rightarrow \eta[/tex];
The first question I have is how can I transform (1) into a system of three first order ordinary differential equations. I have done it yet before with Blasius type equations, but here the density makes it a bit difficult. The aim of my question is to compute both coupled equations with a Non Linear Shooting Method.
Thanks in advance.
You can't do it analitically.It's like [tex]\int e^{\sin x} \ dx[/tex]...Can"t find the sollution.I think there are numerical algorithms in which you can find the values you're looking for...
Daniel.
Dude, that's so interesting. I tell you what, I'm going to work on the easier one (that's a challenge for me):
[tex] f^{'''}+ff^{''}=0[/tex] with [itex](0<\eta<+\infty)[/itex]
[tex]f(0)=f^{'}(0)=0[/tex]
[tex]f^{'}(+\infty)=1[/tex]
I'll attempt to perfect a Runge-Kutta/ "Shooting Method". May take a few days but I'm a good programmer. Then I'll look at yours.
Alright, maybe not a few days, but that's only because I spent all that time on Runge Kutta and those IDEs a few weeks ago. Anyway, the objective here is to find [itex] f^{''}(0)[/itex] via "shooting method". I used simple interpolation to zero into the value of the second derivative at [itex]\eta=0[/itex]. The value I got to 4 places is 0.4696. Attached is a plot of the LHS of the ODE in the range (0,20). The results were no larger than 10^-6. This gives me confidence that the numerical results are ok.
[tex] f^{'''}+\frac{ff^{''}}{2}=0[/tex] with [itex](0<\eta<+\infty)[/itex]
That's a Blasius type problem. The fact is setting up a shooting method for this equation is a bit easier. I made it some time ago. But the problem with my equations is the coupling via density, and reducing it to five first order ODEs.
Clausius, can you kindly clear up something for me as I'm not familiar with the application. Are you saying that rho is a function of Y, that is [itex]\rho=g(Y(\eta))[/itex] and that this function is known? If that' so, then I can derive the following 5 equations:
[tex]F^{'}=vg(Y)[/tex]
[tex]v^{'}=r[/tex]
[tex]r^{'}+\frac{F}{2}r=0[/tex]
[tex]Y^{'}=s[/tex]
[tex]s^{'}+\frac{s^{2}g^{'}(Y)}{g(Y)}+\frac{Fs}{2g(Y)}=0[/tex]
where [itex]g^{'}(Y)[/itex] is the derivative with respect to Y.
saltydog said:
Clausius, can you kindly clear up something for me as I'm not familiar with the application. Are you saying that rho is a function of Y, that is [itex]\rho=g(Y(\eta))[/itex] and that this function is known? .
Yes it is known. Anyway, I have reduced it yet to a 5 first order ODEs. The aim of this is to solve each of them by a Runge-Kutta method, shooting from
-infinite, and converging to the shooting parameters via Newton-Raphson method.
I am having serious troubles at setting up the process, because Newton-Raphson formulae involves derivative respect to shooting parameters in the denominators.
Some web-link or reference to examples of this type of non linear problems solved by means of shooting method would be greatly appreciated.
Clausius, would you please report the five equations here so that I and others can take a look at them.
Thanks,
Salty
[tex] y_1=F[/tex]
[tex] y_2=F'/\rho[/tex]
[tex] y_3=(F'/\rho)'[/tex]
[tex] y_4=Y[/tex]
[tex] y_5=\rho Y[/tex]
which yields:
[tex] y_1'=y_2\rho[/tex]
[tex] y_2'=y_3[/tex]
[tex] y_3'=-0.5y_1y_3[/tex]
[tex] y_4'=y_5/\rho[/tex]
[tex] y_5'=-y_1 y_5/(2\rho)[/tex]
Clausius, you said rho is known. My understanding from you is that it is some functional dependency on Y. Can you supply this functional dependence?
I'd like to begin working on the problem but can't until you define what rho is in terms of the function Y.
Sorry.
[tex] \rho=\frac{1}{Y+\epsilon(1-Y)}[/tex]
with
[tex]\epsilon<<1[/tex]
I'm using Matlab. If you try it, please post me any incidence you have. Actually I am having problems with shooting parameters.
Clausius2 said:
Sorry.
with
Fantastic! Two equation in two unknowns. You know, I'm optimistic there are people in here that can do this one especially now that you've posted rho. I do intend to spend time with it but I'm kinda busy with work now. I'm patient; I spent 12 months on another one some time ago. I suppose you don't have that time though.
Till Friday.
Some qualitative progress:
Consider:
[tex]\rho=\frac{1}{Y+\epsilon(1-Y)}[/tex]
And the boundary conditions:
We can deduce the values of [itex]\rho[/itex] at these boundaries:
[tex]\lim_{n\rightarrow+\infty}\rho=\frac{1}{\epsilon}[/tex]
[tex]\lim_{n\rightarrow-\infty}\rho=1[/tex]
Thus:
[tex]\lim_{n\rightarrow+\infty}F^{'}=0[/tex]
[tex]\lim_{n\rightarrow-\infty}F^{'}=1[/tex]
Am I interpreting the limits correctly?
If so, then I can begin to describe, qualitatively at least, the behavior of F and Y as per the attached plot (or some variant thereof). Note that Y is shown to be a sigmodal type function.
What do you think Clausius? Does the sigmoid function have any relevance in the application you're working on?
I plan to begin numerical work from this qualitative perspective using five first-order ODEs and the "shooting method" to search 3-D space for three of the five initial conditions, holding F(0) and Y(0) constant (at first). I'll attempt to set up a "quasi-random" search of the space to try and zero-in on a solution. May take a while . . .
Clauius, I don't know where you at, but this is what I'm going with, "win-loose-or draw":
[tex]F^{'}=\frac{v}{y+\epsilon(1-y)}[/tex]
[tex]Y^{'}=s[/tex]
[tex]r^{'}=-\frac{F}{2}r[/tex]
[tex]v^{'}=r[/tex]
[tex]s^{'}=-s[Y+\epsilon(1-Y)][\frac{s(\epsilon-1)}{(y+\epsilon(1-y))^2}}+\frac{F}{2}][/tex]
with:
[tex]F(0)=a[/tex]
[tex]F^{'}(0)=c[/tex]
[tex]F^{''}(0)=k<0[/tex]
[tex]Y(0)=b[/tex]
[tex]Y^{'}(0)=d<0[/tex]
and:
[tex]r(0)=k(b+\epsilon(1-b))-c(\epsilon d-d)[/tex]
[tex]v(0)=c(b+\epsilon(1-b))[/tex]
[tex]s(0)=d[/tex]
Note that [itex]F^{''}(0)<0[/itex] and [itex]Y^{'}(0)<0[/itex] in keeping with the qualitative results stated earlier.
So, I'll keep F(0) and y(0) constant, (with small [itex]\epsilon[/itex]), and search a 3-d space of F'(0), F''(0), and y'(0) using a Halton sequence (quasi-random): Do a Runge-Kutta at each point, check the boundary at some max point, find the closest match. If something pans-out, restrict the search around that point. The attached is the Halton sequence distribution.
You know, if anybody else has a better idea I'd be interested.
Just a correction:
The expression for [itex]s^{'}[/itex] above is incorrect. It should be:
[tex]s^{'}=\frac{\epsilon s^2-s^2-0.5 s v \rho}{\rho+0.5 F \rho^{2}}[/tex]
I've coded the algorithm to search for solutions that I stated above. My initial results, although not successful, are encouraging as some numerical results seem to tending to the qualitative results stated earlier. I plan to continue working with it.
Clausisus, I hope I'm not distracting you in regards to your application. You know, some people work cross-word puzzles for fun. I seem to have chosen DE's for some reason . . .
saltydog said:
Just a correction:
THANKS for your help, saltydog.
I have solved the problem. If you want to know how to do about it, let me know. Hey! it seems this thread has been put upside down, now I am who is offering aid! :rofl: .
Of course I'd like to know how you solved it. Please give me the details. My understanding is that the initial conditions F(0) and Y(0) needed to be known to solve it for a practical application. Is this not the case?
Thanks a bunch,
Salty
Thanks a bunch,
Salty
What do you mean? I don't need to know the values of F and Y at [tex]\eta=0[/tex] in order to solve the problem. It is closed with the boundary conditions I posted.
Do you ever have implemented a code of shooting method? If so, let me know.
Ok Clausius, I'm beginning to understand your 5 equations are nicer. However, I think you made a typo for [itex]y_5[/itex]. It should be:
[tex] y_5=\rho Y^{'}[/tex]
Right?
I do not understand how the problem is closed. I have the Mathematica code implemented to study five equations and is a simple matter to switch the derivatives for each one. I'll spend more time with it and your equations.
yes, I made a mistake. You're right about y5.
The problem is closed. Go to my first thread and take a look at the boundary conditions. There are 5 boundary conditions for a system of equations of third order (the first one) and second order (the second one). You do not need any additional condition.
Ok Clausius. I'm weak with boundary value problems like this (well, other stuf too but I digress). But I'm ok with that. This is my plan: Using my Mathematica program, I'm just going to search 5-space using a 5-D quasi-random distribution and attempt to zero-in to the "initial condition" which tends to the boundary conditions specified. I mean, I have a 2 GHz machine and I'll just let it run. Can you at least tell me if that is an appropriate means of attack?
Thanks,
Salty
Thanks,
Salty
Hummmmm . . . my initial results are looking encouraging . . . got to go though. Will get back to it tonight.
Well, I have an answer but I don't like it:
[tex]F(\eta)=\left\{\begin{array}{cc}F_1(\eta),&\mbox{ if } \eta>0\\F_2(\eta),&\mbox{ if }\eta<0\end{array}\right[/tex]
That is, it's discontinuous at the origin.
Same thing for [itex]Y(\eta)[/itex]. Back-substitution of the results into the ODEs produces low discrepancy from zero but I'm not impressed with it.
Anyway, if nobody wants to summarize a better solution, I'll write this one up in a few days.
Not, the solution is not discountinous at all. Don't forget what is the origin of the problem. It cannot be a discontinuity anywhere.
Here is a plot of the solution F'/rho (solid line) and Y (dashed line). I hope you could see it.
Thanks Clausius. What value of [itex]\epsilon[/itex] did you use?
Also, what does the plot look like for [itex]\eta<0[/itex]?
Sorry, I missed your last post.
The value of \epsilon is 0.056. If you look at the vertical axis, there are also negative values of \eta computed.
1. What is a Heavy ODE System?
A Heavy ODE (ordinary differential equation) system is a set of differential equations that involves a large number of variables and can be computationally intensive to solve. These systems are often used to model complex physical processes, such as fluid flow or chemical reactions.
2. What is the Round Jet Near Field?
The Round Jet Near Field refers to the region immediately surrounding a round jet, which is a type of fluid flow where a high-speed stream of fluid is ejected into a lower-speed surrounding medium. This near field is of particular interest in engineering and scientific research, as it is where many important flow characteristics, such as turbulence and mixing, can be observed and studied.
3. Why is it important to solve the Heavy ODE System for computing the Round Jet Near Field?
The Round Jet Near Field is a complex physical system that is difficult to model and understand. By solving the Heavy ODE System, we can obtain numerical solutions that provide valuable insights into the behavior of the near field, such as the distribution of velocity and pressure, and the development of vortices and other flow structures.
4. What methods are used to solve Heavy ODE Systems?
There are several methods for solving Heavy ODE Systems, including finite difference methods, finite element methods, and spectral methods. Each method has its own advantages and disadvantages, and the choice of method often depends on the specific characteristics of the system being studied and the desired level of accuracy.
5. What are some challenges in solving Heavy ODE Systems for computing the Round Jet Near Field?
Solving Heavy ODE Systems for the Round Jet Near Field can be challenging due to the large number of variables and the high level of accuracy required. This can lead to long computation times and the need for powerful computing resources. Additionally, the non-linear behavior of these systems can make it difficult to accurately model and predict the behavior of the near field.
  • Differential Equations
