Heegard Splitting of the 2-Torus.
  • Thread starter Thread starter WWGD
    Splitting
WWGD
Homework Helper
Hi, All:
First of all, the title should be "Heegard Splitting of ## S^3 ## ; the 2-torus is not even a 3-manifold.
I think I have a way of showing that ## S^3## can be decomposed as the union of two solid tori ## = S^1 \times D^2 ## ,but the argument seems more analytical than geometric. I'm also trying to avoid, if possible, to make heavy use of the Hopf fibration. I wonder if someone has a "nice " geometric way of describing it.
The argument is something like this (it does use the Hopf fibration): consider a trivialized 'hood U in the bundle ## π: S^3 \rightarrow S^2 ## with fiber ## S^1 ## , i.e., U lifts under π to a product ## U \times S^1 ## . Then we take a disk ## D^2 ## inside of U ( or inside of me ), which will lift to a ## D^2 \times S^1 ## , i.e., a solid torus. Now we consider the lift of the complement in ## S^2 ## of this last ## D^2## ; we have that ## S^2 - D^2 ## is a ## D^2##, which is contractible, so that if lifts also to a ## D^2 \times S^1 ## . Maybe we need to give some smooth gluing arguments of the two lifts, but otherwise I think this shows this decomposition. Can anyone think of some other nicer way of showing this without considering the lifts of copies of ## S^1 ## in the base ## S^2## in the Hopf fibration?
Thanks.
Notice S3 is the boundary of D4. Since D4 = D2 x D2 and the boundary of this latter space is (D2 x S1)∪(S1 x D2) the conclusion follows. Although this argument works topologically some additional care might be needed to ensure it translates properly into the smooth setting.
Ah, nice; thanks.
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
