Heights of two balls thrown at the same time
  • Thread starter Thread starter Quantum Mind
    Balls Time
Two balls are thrown simultaneously at angles \Theta and (90-\Theta) with an initial velocity of 39.2 m/s, with one reaching 50 m higher than the other. The discussion highlights the importance of using the correct vertical and horizontal components of velocity, as well as the need to express equations in terms of \Theta. The calculations led to heights of 14.2 m and 64.2 m for the two balls, which were confirmed through kinematic equations. Trigonometric identities, such as sin(90°-θ) = cos(θ), were emphasized as crucial for solving the problem accurately. Understanding these concepts is essential for correctly analyzing projectile motion.
Quantum Mind
A ball is thrown at angle \Theta and another ball is thrown at an angle (90-\Theta) with the horizontal from the same point with velocity 39.2 m/s. The second ball reaches 50 m higher than the first. Find the heights.
v = u -gt where v is the final velocity and u the initial velocity ( u = 39.2 m/s and v = 0)
S = ut - 1/2 gt2
Since the angles were not given, I did not find the vertical and horizontal component of velocity. I tried to find the time taken to reach the maximum height using v = u - gt and got the value as 4. I then substituted this value in the second equation and got the answer as 78.4 m. Since it says that one ball reached 50 m higher, I should either add or subtract 50 from this. Can I assume that this height is of the second ball ? Why not the first ? Even assuming that this is for the second ball, I get the answer as 28.4 and 78.4 m whereas the answer is 14.2 and 64.2.
I then attempted to solve the problem using the second equation by assuming the heights as S and S+50 with u remaining the same. However t would vary and the equation was not leading anywhere.
Where did I go wrong?
It is to be assumed that both balls have the same initial speed, 39.2 m/s otherwise you cannot solve the problem. If the angles are not given, just use θ, but you cannot assume that the y-component of the velocity of any ball is 39.2 m/s. This would mean it is shot straight up which is just not true. Write the kinematic equation 2a(Δy)=vy2-v0y2 for each ball and see what you get.
You're trying to solve for θ, so you want to eventually end up with an equation that has θ in it, which you can solve. In other words, as kuruman said, "If the angles are not given, just use θ," so you'll end up with an equation with θ in it.
Your instructor has probably recommended you try to solve problems algebraically first and plug numbers in at the end. One of the reasons this is a good idea is to avoid the mistake you've made. Just because you can't calculate a number for vy right at the beginning doesn't mean anything is wrong. It just means you need to leave it in terms of θ, which is exactly what you want because you want to end up with an equation with θ in it.
Since time is not given, I have to use the formula v2 = u2 - 2aS.
For the first ball, v i.e. final velocity is 0 and u initial velocity is 39.2 Sin\Theta m/s and a is 9.8 m/s2 and S is the distance.
1536.64 Sin2\Theta = 19.6 S
For the second ball,
1536.64 Sin2(90-\Theta) = 19.6 (S+50).
So I get two equations,
19.6S = 1536.64 Sin2\Theta ------- A
19.6S + 980 = 1536.64 Sin2(90 - \Theta) -------- B
A + B
39.2S + 980 = 1536.64 Sin 90
39.2S = 1536.64 - 980 = 556.64
S = 14.2 m and S+50 is 64.2 m.
Is my working correct ?
It looks correct, but why do you say that sin2θ+sin2(90o-θ) = sin90o? Is that always true? I know the answer, but I want to make sure that you do too.
That is why I was unsure whether my working was correct. Can you give me a hint ?
Is there any other way to arrive at the answer ?
Use the trigonometric identity sin(90o-θ)=cosθ and see what you get.
Sin2\Theta + cos2\Theta = 1
I am yet to learn the trig identities fully, thanks for pointing it out.
An important trig result that you will have to use over and over again is "If two angles add up to give 90o, the cosine of one is the same as the sine of the other." Try to remember that. :wink:
