Hello Guys: Angle of Incidence & Emergent Ray - Compare & Answer Problems
  • Thread starter Thread starter franz32
When a ray of light passes from air into a glass plate, the angle of incidence is equal to the angle the emergent ray makes with the normal. To solve related problems, extend the rays in a sketch and apply geometric principles. If angles are provided relative to the surface, use their complements to determine the angle of incidence. The discussion also highlights the importance of understanding the index of refraction and Snell's law for accurate calculations. This foundational knowledge is essential for solving optics problems effectively.
franz32
Hello guys!
I hope someone can help me here...
How do I compare the angle of incidence and the angle the emergent ray makes w/ the normal when a ray of light passes from air through a glass plate? From here, I can answer my other problems...
They're equal. If you need any other angles, extend the rays on your sketch and use geometry to find what you need. Remember, if they give you the angle relative to the surface to use its complement as the angle of incidence.
Banana, he is talking about light passes through glass. You are talking about light reflecting on a mirror.
Franz, Look up index of refraction and snell's law.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
