Helmholtz Decomposition: Magnitude of Irrot. & Solenoidal Comp.
The discussion revolves around the Helmholtz decomposition, specifically focusing on the relationship between the magnitude of the integral of the gradient of a scalar potential and the integral of a vector field over a specified domain. Participants explore the implications of integrating over all space and the behavior of potentials at boundaries, particularly in the context of fluid dynamics.
  • Nick introduces the problem of comparing the magnitudes of integrals involving the gradient of a scalar potential and a vector field, noting the dependence on the shape of the integration domain.
  • Nick expresses confusion regarding the integration of surfaces at infinity and its implications for the physicality of the results.
  • Nick proposes that if the vector field is nonzero only in a finite domain and approaches zero at the boundary, the integral of the gradient of the scalar potential can be rewritten using the divergence theorem.
  • Nick suggests that if the scalar potential is constant on the boundary, it must be zero to avoid contradictions with the fixed total input of the vector field.
  • Another participant questions whether the condition of the gradient being zero on the boundary necessarily implies that the potential is constant outside the domain, raising doubts about the assumption that the vector field is zero outside the domain.
  • A later reply references the Helmholtz decomposition and provides a formula for the scalar potential, suggesting that if the vector field behaves well and diminishes at infinity, the surface integral vanishes.
Participants express differing views on the implications of boundary conditions for the scalar potential and the behavior of the vector field outside the defined domain. The discussion remains unresolved regarding the assumptions and conclusions drawn about the scalar potential and its implications.
Participants note limitations related to the assumptions about the behavior of the vector field and the scalar potential at boundaries, as well as the mathematical rigor required to support their claims.
nickthequick
Hi, Consider P = \boldsymbol{\nabla} f +\boldsymbol{\nabla}\times \bold{A}
where f and A are scalar and vector potentials, respectively, and P is strictly positive and well behaved, and only nonzero in a domain \mathcal{D}.
I want to find how the magnitude of
\int \boldsymbol{\nabla} f dV and see how it compares to the size of
\int P dV where we are integrating over all of space \mathbb{R}^n for n the number of dimensions we are working in.
I can use Green's functions to find f in terms of P. I test my results with examples, but when I integrate over all of space to find the magnitude of this term, it appears as if the value I find is dependent on the shape of the integration as I let it go to infinity. This seems non-physical since I have a fixed total input P.Any suggestions would be greatly appreciated.
PS This problem comes from trying to figure out the momentum partitioning between irrotational and rotational fluid flows, if that adds any context.Cheers,
Nick
I don't think there's an easy trick here, so perhaps you could elaborate on this apparent dependence on the shape of the integration domain to see if that can be rooted out directly instead?
The problem I was having was happening when I was dealing with integration of surfaces at infinity. This confuses me for a variety of reasons and I'm not sure that I even need to address this issue. Instead, let's discuss what I am really interested:
Assume \vec{P} is nonzero, is in a finite domain \mathcal{D}, is only acting in the \hat{x} direction, and goes to 0 (in a suitable mathematical way) as we approach \partial \mathcal{D}.
I want to find
I_1 =\int_{\mathcal{D}} \vec{\nabla} f \ dV,
where V is an integration over \mathcal{D}. By the divergence theorem, I can rewrite the above integral as
\int_{\partial \mathcal{D}} f \ d\vec{A},
\nabla f=0 on the boundary which implies that f is a constant here. This implies f must be constant for all of region outside of \mathcal{D}, else it would induce a nonzero gradient and would violate P being non zero outside of \mathcal{D}.
My intuition tells me that we should be even more restrictive with f, and say it is zero on the boundary. This comes from the fact that as we let the domain get large, if f is constant the integral I_1[\itex] keeps getting larger, which is nonsensical because the total integral of P is fixed. So this would imply that f must be identically zero on the boundary and for the rest of the domain. <br /> <br /> Again, this is all very hand wavy, so any hints as to actually showing this is rigorously the case would be most desirable.<br /> <br /> Nick
The points of logic that give me trouble: does \nabla f = 0 on the boundary necessarily imply that f is constant outside the domain? ...it probably does, I guess, given the assumptions you've made, but that leads me to question the assumption that P is zero outside the domain. I'm afraid I don't see why this is a useful property (even knowing how it plays into realizing that f is constant outside).
Anyway, if you see the wiki page on Helmholtz decomposition, it suggests that the form of the scalar potential is
f(r) = -\int_{\mathcal D} \frac{\nabla&#039; \cdot P(r&#039;) \; dV&#039;}{4\pi |r - r&#039;|} + \int_{\partial \mathcal D} \frac{P(r&#039;) \cdot dS&#039;}{4\pi |r - r&#039;|}
And that as long as P is sufficiently well-behaved and falls off toward infinity, the surface integral vanishes.
