Help cant figure this question out
  • Thread starter Thread starter camo2412
    Figure
A 20kg block attached to a 3.5kg mass via a frictionless pulley is analyzed to determine if the mass is sufficient to start the block moving. The static friction force required to overcome is calculated to be 39.2N, while the force exerted by the 3.5kg mass is only 34.33N. It is concluded that an additional force of 5N is necessary to initiate movement, which corresponds to an extra mass of approximately 0.5kg. The calculations confirm that without this additional mass, the block will remain stationary. Therefore, the required additional mass to start motion is correctly identified as 0.5kg.
camo2412
a 20kg block rests on a horizontal surface and is attatched to a mass of 3.5kg by a cable,the pulley is frictionless ans the coefficient of static frition is 0.2
prove that the mass is not suffcient to start the block moving,what is the additional mass that would be requaired to start motion
http://img818.imageshack.us/img818/9962/37642403.png
20kg block Ff=39.24 Fn=196.2
3.5kg block Fw=34.33
i can work out the acceleration which is 6.68 m/s
but i just don't know hwo togo about working out what it is asking to do,as in prove the mass is not sufficient to start the block moving,what additonal forceis needed
any help would be great Thanks
What makes a body move from rest? Can you relate to any laws?
Hi camo2412! Welcome to Physics Forums.
I'm puzzled about the acceleration you say you have worked out. The masses won't move, because the smaller one exerts a horizontal force of (according to your figures) 34.33N, while your calculations determined that a force of 39.2N is needed to overcome the bigger block's friction.
thanks nas
the acceleration calculation i did shouldn't have been in the that was another question is was working out sorry.
but yes from what i undertstand it won't move until another extra 5n is applied,
therefore i think is its an extra .5kgs that is needed
.5x9.81=4.9 which rounded up let's say 5n
just unsure if this is correct answer to the question?
Sounds about right to me. :smile:
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
