Help- electric/gas hybrid go kart project
  • Thread starter Thread starter RacerDad22
    Project
A user is converting an electric go-kart into a gas/electric hybrid and seeks assistance in creating a buy list for microcontrollers and sensors. They plan to use an RPM sensor, angular position sensor, and servos for throttle control, while managing the interaction between electric and gas throttles based on wheel RPM and gas pedal position. Recommendations for online shops and resources for microcontrollers like Raspberry Pi and Arduino are appreciated, as these platforms have extensive support and active forums. One suggestion includes using the gas motor to drive an alternator for battery charging instead of directly powering the wheels. The discussion emphasizes the need for effective control and programming solutions for the hybrid system.
RacerDad22
hey all- I've built a elec go kart using a 24v source, PMC high amp speed controller, and massive 24v excavator starter motor. Fun stuff. I want to make it gas/hybrid. I'm not going to lay out all the challenges- but I do need help on building a buy list for micro controllers/sensors etc. I haven't done Microcontrol programming/build in 15yrs- sooo.. I'll pay more for "more built" or easier programming.
Here's what I think I need:
-RPM sensor (drive wheel)
-angular position sensor (gas pedal)
-servo x2 (gas and elec throttle control)
-Microcontrol that can handle the inputs/ drive servos
Without getting into the mud of the logic- general thoughts- based on drive wheel rpm, engage elec throttle servo based on gas pedal position, until certain rpm reached, then taper on gas throttle servo, tapper back elec throttle servo until higher rpm- then zero elec throttle servo
Also- appreciate any recommendations on good online shops for such.
Thx!
There are very extensive sensors and actuators available for both Rasberry Pi and Arundino microcontrollers. There are also very active forums for both. I think you might get better answers from one of those forums.
Good luck
Ok. Thx, I see some external forums on topic, none here. One step closer.. Peace.
Instead of having the gas motor drive the wheels have you considered using the gas motor to drive an alternator to keep the battery charged? I think that might be easier to control.
Thread 'Weird near-field phenomenon I get in my EM simulation'
I recently made a basic simulation of wire antennas and I am not sure if the near field in my simulation is modeled correctly. One of the things that worry me is the fact that sometimes I see in my simulation "movements" in the near field that seems to be faster than the speed of wave propagation I defined (the speed of light in the simulation). Specifically I see "nodes" of low amplitude in the E field that are quickly "emitted" from the antenna and then slow down as they approach the far...
Hello dear reader, a brief introduction: Some 4 years ago someone started developing health related issues, apparently due to exposure to RF & ELF related frequencies and/or fields (Magnetic). This is currently becoming known as EHS. (Electromagnetic hypersensitivity is a claimed sensitivity to electromagnetic fields, to which adverse symptoms are attributed.) She experiences a deep burning sensation throughout her entire body, leaving her in pain and exhausted after a pulse has occurred...
