MHB Help find eqn of circle given another circle that is tangent
  • Thread starter Thread starter sktrinh
    Circle Tangent
The discussion focuses on finding the equations of two circles with a radius of 10 that are tangent to the circle defined by X^2 + y^2 = 25 at the point (3,4). The centers of the circles are determined to be at (-3,-4) and (9,12), both of which are 10 units away from the tangent point along the line y = 4/3x. The participants explore algebraic methods to derive these centers using distance formulas and the relationship between the coordinates. The final equations of the circles are established as (x-9)^2 + (y-12)^2 = 100 and (x+3)^2 + (y+4)^2 = 100. The discussion concludes with a confirmation of the centers and their respective equations.
sktrinh
please help me find the standard equation of the circles that have radius 10 and are tangent to the circle X^2 + y^2 = 25 at the point (3,4).
the soln: (x-9)^2 + (y-12)^2 = 100, (x+3)^2 + (y+4)^2 = 100,
i found the eqn that intersects the centre of the small circle and the larger one to be: y=4/3x, substituted as k=4/3k for C(h,k) into the eqn of the circle, however require some help solving it. thanks!
Mathematics news on Phys.org
I would simply observe that the center of one circle must be at (-3,-4) and the other at (9,12). These points are both 10 units from the tangent point along the line you correctly found.
is there a algebraic way of solving it using distance formulas like d = |ax+by+c|/sqrt(a^2+b^2°+) or something else?
I solved for eqn of line of the that passes thru both the small and large circle being y=4/3x, and set k=4/3h since it passes thru the large circle as well (i think), with this expression i plugged into (3-h)^2 + (4-k)^2 = 100
(3-h)^2 + (4-4/3h)^2 = 100
I couldn't solve this thru, i keep getting h^2 -6h -9, which i think shud be h^2 -6h + 9, so that h = -3 and which would follow k = -4. How would I solve in a similar fashion for the second large circle as impled by the solution of C(9,12)??
Well, we know the centers of all circles will lie on the line:
$$y=\frac{4}{3}x$$
And so the center of the two tangent circles will be at:
$$(h,k)=\left(h,\frac{4}{3}h\right)$$
And since the must both pass through the point $(3,4)$, we may state:
$$(3-h)^2+\left(4-\frac{4}{3}h\right)^2=100$$
$$(3-h)^2+\frac{16}{9}\left(3-h\right)^2=100$$
$$\frac{25}{9}\left(3-h\right)^2=100$$
$$\left(h-3\right)^2=6^2$$
$$h=3\pm6$$
This implies:
$$h=-3,\,9$$
And using the relation between $h$ and $k$, which is $$k=\frac{4}{3}h$$ , we then conclude the centers are at:
$$(-3,-4),\,(9,12)$$
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
