HELP Helicopter Center of Moments
The discussion revolves around the calculation of the helicopter's center of moments in the context of a helicopter simulation. Participants explore the implications of forces acting on the helicopter, such as lift from the main rotor and gravitational forces, while considering the effects of inclination and stability.
  • Fred questions the appropriate location of the center of moments, suggesting it should be between the center of gravity and the main rotor axis to account for torque generated during inclination.
  • Some participants propose that the center of mass should be the reference point for calculating forces, as lift acts from the rotor plane and gravity pulls directly downward.
  • Fred expresses uncertainty about calculating the center of moments, indicating that existing literature does not provide a clear answer.
  • Another participant suggests defining a body frame with the origin at the center of mass to analyze aerodynamic and propulsive forces effectively.
  • Fred mentions using formulas from various sources, including Johnson's Helicopter Theory, to calculate rotor thrust and torque, indicating a reliance on blade element theory.
  • There is a discussion about the implications of the tail rotor's position on the overall stability and moments acting on the helicopter.
Participants do not reach a consensus on the exact location of the center of moments, with multiple competing views on how to approach the calculations and the implications of different configurations. The discussion remains unresolved regarding the optimal method for determining the center of moments.
Limitations include the lack of clarity on how to calculate the center of moments and the dependence on various assumptions about the forces acting on the helicopter. The discussion also reflects a range of knowledge about simulation techniques and theoretical frameworks.
Individuals interested in helicopter dynamics, flight simulation development, and the application of aerodynamic principles in modeling may find this discussion relevant.
fred64
Hi,
I am creating an helicopter simulation and have a question about calculating the correct helicopter origin of moments.
In its simplest terms, ignoring drag and tail rotor forces and torques I have the main rotor generating an upward thrust from the rotor hub, and gravity generating weight from the center of gravity.
In normal rigid body physics the center of moments is in the center of gravity, being the helicopter suspended at a rotor in my opinion it should be somewhere in between the two.
It can't be at the center of gravity as if the helicopter is inclined in any direction i.e. forward, the main rotor will generate a pitch torque which is not balanced back and the helo will fall nose down...
From my tests the ideal position is centered on the main rotor axis and in line with the perpendicular to the main rotor axis that intersects the tail rotor axis, which otherwise will cause a rolling torque.
I also looked at several helicopter aerodynamics books (especially Bramwell and Johnson) but found no answer.
thanks in advance
Fred
Are you using BEMT in your simulation?
No I wrote my own sim in NET, I don't know BEMT. Actually it's a flight simulation software.
I take it you are at the first stage of analysis where you don't yet look at gyroscopic forces.
Find the center of mass of the helicopter. Gravity pulls this directly downward.
Lift acts from the center of the rotor plane. The force of lift due to the rotor is directed along it's axis of ratation.
Both of these forces pass through the center of mass; no torsional forces arise on the aircraft.
thank you Phrak,
yes gyroscopic forces are next. BTW where can I find a formula to simulate the gyroscopic stability generated by the turning rotor (I think it will depend on Moments of Inertia, angular velocity, force applied) maybe the formulas for a bycicle could work...
Regarding my question, i think your answer is fine as long as the rotor force is in line with the center of mass. when I incline my rotor forward the force is inclined forward, this should create a torque equal to square the distance from the rotor hub to the center of mass per sin the inclination angle.
If the center of moments is at the center of mass, there is no corresponding countertorque from the gravity force and the helicopter will be unstable (fall forward), so my guess is that the center of moments is in between the two and that weight creates an opposite torque (very much like a pendulum), but I found no way to calculate this...
thanks in advance
Fred
Errr...BEMT is the theory you use to calculate the rotor thrust, torque etc. Its not a language. As a flight dynamcist that does simulation, I've never heard of net before. Is this some sort of freeware?
I'm not an expert on helicopter simulation, but I think you need to first define an appropriate body frame with origin at the center of mass. The aerodynamic/propulsive forces and moments can then be calculated in the body frame, and the appropriate equations for translational and rotational dynamics in the body frame are used. If you don't have any background in flight dynamics, I strongly suggest reading chapter 4 of Pamadi's book. It clarifies a lot of these concepts.
thank you Brian,
in fact the simulation as you mentioned it is already almost finished and it works quite well (it's a module that integrates into Microsoft Flight Simulator), I studied all the formulas from different books and adapted them for the software, Bramwell gives some indication on the Center of Moments being the perpendicular from the center of gravity to the main rotor axis, but this gives an unstable model when the center of gravity is on the same axis as the main rotor axis, so possibly he meant the "vertical" from the rotor axis which would give a more stable configuration except for the following.
From how helicopter are designed if you consider also the tail rotor this will also bring a torsional moment in case it is not on the same axis as the center of moments, so possibly the center of moments is a cross line between the main and tail rotor axes (that's how I designed it for the moment)
Thanks
Fred
Sorry I did not know the acronym, I guess it means blade element theory. To calculate rotor thrust and torque, induced velocity, H forceI mostly used formulas taken from Johnson's Helicopter theory, which uses blade element theory. I used a simplified iterative calculation between thrust and induced velocity as I need to perform all the aerodynamic calculations (including drag, stabilizers etc...) 20 times a second...
Fred
Fred
Great! I'm glad (finally) someone's coding a sim around here correctly! :smile:
11K
  • · Replies 34 ·
10K
  • · Replies 32 ·
13K
