Limit Evaluation Help: How to Simplify a Limit Involving Rational Functions
  • Thread starter Thread starter f(x)
    Limit
f(x)
Evaluate: \lim_{x \rightarrow \infty} ( \frac {x^3}{(3x)^2-4}-\frac{x^2}{3x+2} )2. The attempt at a solution
First i took x^2/3x+2 common, and then substituted y=1/x , y->0.
simplifying, i get \frac{-2}{9y}...i am unable to eliminate all the y's.
The answer given at the back of the book is 2/9.
Plz help me figure this out.
&&Thx
Are you sure that's exactly the question? The limit approaches minus infinity...
There is a theorm for this because what you have is an \infty/\infty correct? (L'Hopital)
Note: If this is a calc one qustion ignore this.
yeah, that's why i am confused
EnumaElish said:
The trick is to convert each term with x's into a term with 1/x's.
What do you need to divide with both the numerator and the denominator of the first term, to convert all the x's into 1/x's?
What do you need to divide with both the numerator and the denominator of the second term?
Say for the 1st term, i divide and multiply by x^3, the Dr. becomes 0 ?
Are you sure the question isn't:
\lim_{x \rightarrow \infty} ( \frac {3x^3}{(3x)^2-4}-\frac{x^2}{3x+2} )
i keep getting \infty not 2/9
Find a common denominator, then add the fractions together.
I checked it again, but the question is exactly as I put it.
(3x)^2 - 4 = 9x^2 - 4 = (3x + 2)(3x - 2)
use this to simply your function (i.e multply your second term with (3x -2) in both nominator and denominator)
Then the x^3 term will vanish
Also, there must be a misprint as "learningphysics" has noticed
I'm guessing it's a misprint or something that left out the 3... because the limit of the function I just posted is 2/9.
