Can a Scalar Multiple of a Basis Still Form a Basis?
  • Thread starter Thread starter Rijad Hadzic
    Basis
A basis for a vector space can have multiple representations, including scalar multiples of its vectors. If {v_1, v_2, ..., v_n} is a basis, then the set {cv_1, cv_2, ..., cv_n} (where c is a nonzero scalar) also forms a basis due to its linear independence and ability to span the same space. The confusion arises from the misconception that a vector space can only have one basis; in reality, different bases can represent the same vector space. The key is that any linear combination of a basis that maintains independence will still span the space. Understanding these properties clarifies the nature of bases in vector spaces.
Rijad Hadzic
I'm using this problem, and although I got the correct answer my question is really about the properties of a basis, not the problem that I'm going to state..
anyways,
Let = {v_1, v_2, ..., v_n } be a basis for a vector space V. Let c be a nonzero scalar. Show that the set {cv_1, cv_2, ..., cv_n } is also a basis for V
Since the set {cv_1, cv_2, ..., cv_n } has the same dimensions as set {v_1, v_2, ..., v_n }, I now only need to check for linear independence (or span, but it makes no sense to check for the more difficult condition.)
So [ k1cv1 + k2cv2 + ... kncvn = 0
the set consists of vectors {v_1, v_2, ..., v_n }, which was stated to be a basis, thus implying that any set with these vectors must = 0 for each constant,since c is a nonzero scalar, and this must mean that k1 through kn are all zero.
Does this seem like a logical/correct conclusion?
Anyways, my real question is:
It says that c is any nonzero scalar, but this doesn't make sense to me.
I was under the impression that a vector space can only have one basis. This problem contradicts that belief. Maybe my understanding of the terminology is wrong, but if a basis is a scalar multiple of another basis, they are essentially the same basis, right?
Sorry I know my wording for this question doesn't really make sense, I hope you guys can understand what I'm saying.
Through finishing this question, my train of thought is as follows:
Since a basis is
1) a linear combo which will = 0 if and only if the constant multiple is = 0, (its linearly independent)
2) spans every vector in the vector space (meaning every single vector in the vector space can be formed by the basis)
that means that you can have "multiple" basis, all being scalar multiplies of each other, because by taking a scalar multiple of those multiple basis, you can construct any vector in the vector space V.
Again I apologize because reading this I truly understand how stupid my questions sound but I'm having a hard time grasping these concepts, so please bear with me.
Also I posted this in precalculus since the problem doesn't involve any understanding of calculus. I hope this is in the correct section and I ask of the mods to move it if its not.
You are over-thinking this. Consider any vector in the space, write it in terms of the given basis vectors {v_1, v_2, ..., v_n }, convert that expression to a linear combination of {cv_1, cv_2, ..., cv_n }. That does it.
You are wrong about there only being one set of basis vectors. Not only any nonzero multiplier, but lots of other linear combinations of a basis will also be a basis. Like {v_1, v_2+v_1, ..., v_n+v_1} will be a basis.
I don't think so.
Let's consider a simpler space, ##\mathbb R^2## and a set of two vectors: ##\vec u = <1, 0>## and ##\vec v = <2, 0>##.
I notice that the equation ##c_1\vec u + c_2 \vec v = \vec 0## is true when ##c_1 = c_2 = 0##. Does this imply that 1) ##\vec u## and ##\vec v## are linearly independent, and 2) that these two vectors form a basis for ##\mathbb R^2##? After all, there are two vectors.
Mark44 said:
I don't think so.
Isn't that different from this cause though, because it's not explicitly stated that u and v form a basis?
My point is that for any vectors u and v, we can always set up the equation ##c_1\vec u + c_2\vec v = \vec 0##, and find that ##c_1=0## and ##c_2 = 0##, whether or not u and v are linearly independent.
My earlier reply was base on what you said here.
I didn't notice that you had said this, later on.
Rijad Hadzic said:
Since a basis is
That "if and only if" part is a subtlety that a lot of students miss. Clearly you get it, so my earlier post wasn't needed.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
