Is Sin^2(a) Equal to Sin^2(b) + Sin^2(c) Only in a Right Triangle at A?
The discussion centers on proving that sin^2(a) = sin^2(b) + sin^2(c) if and only if triangle ABC is a right triangle at angle A. Participants express confusion over the proof, noting that the equation holds true specifically when angle A is the right angle. It is emphasized that transforming sin^2(a) can aid in the proof, particularly by applying Pythagorean theorem concepts. The relationship between angles in a triangle is also highlighted, with a+b+c equating to π being a common trait of all triangles. Ultimately, the proof hinges on recognizing that angle A must be the right angle for the equation to hold.
Andrax
prove that sin^2(a)=sin^2(b)+sin^2(c) if and only if ABC is a right triangle in A
i worked really hard on this one I'm really confused why i didn' get the answer
a+b+c=pi
tried turning everythng to cos 2x didn't helpi really couldn't do this one, can't use complex numbers by the way...please help
Well, a+b+c = \pi is going to be true of all triangles, so that's not necessarily going to be much help.
What does ABC being a right-angled triangle in A imply for the value of a? What does that imply for the value of b+c? What does that imply for the value of \sin^2 a?
i tried everything you said also transforming \sin^2 a won't help me since i want to keep sin a
Transforming \sin^2 a will help you. In fact, the easiest way I can see of proving the result from right-to-left (remember for an "if and only if" you need to prove it both ways) is to show that \sin^2 a = k = \sin^2 b + \sin^2 c for some specific number k whose value you'll have to work out.
Like I asked, if the triangle is right-angled in A, what can you say about the value of 'a'? You can be very specific!
\sin((\pi/2) - \theta)=\cos(\theta)
Also, for this to be true, a must be the right angle of the right triangle.
solved using Pythagoras's theorem --> let abc be a triangle wehave sin a^2 = AB^2 etc..
thank everyone..
