How Does Distance Affect Photocell Output?
  • Thread starter einstein2603
In summary, the conversation is about a student seeking help with an assignment on investigating the output of photocells at different distances from a point source of radiation. Various methods and circuits are suggested, with the use of an ammeter and an operational amplifier being the most feasible for a high school student. It is also mentioned that this concept can be applied to automatic doors using photointerruptors. The conversation concludes with a discussion on the appropriate distances to vary and use for the experiment.
  • #141
could you help me with the apparatud that will be used for this experiment
  • #142
Ok here's my take on things.
I am also doing this experiment and whil it seemed a bit strange at first its not so bad. Really just asking berkemen and hootenanny whether what I've done is the right sort of lines. A few people have mentioned batteries. however having done a bit of reading on photocells i thought they generated current themselves, so I've left out a battery. By the way not sure if anybody has acctually clarified this. We don't acctually do the experiment, just plan it. my plan is to have the photocell connected to a fixed resistor with a large resistance, and to measure the voltage acroos that large resistance. From that i could work out the current using simple maths.
think that's right but just a yes or no would help enormously
  • #143
welshdragon said:
Will you please help I am confused
Ive been told by my physics tutor to connect the photocell to a battery, and take a reading of the current.
Would this work?
THANX
Yes, this should work but you may only obtain a limited range of data.
~H
  • #144
This would probably work, but it would depend on how sensitive your voltmeter is and it is likely your obtained curve will not be nice . If you want simplicity a better method to use would be to connect your photocell directly to an ammeter and measure the current.
~H
  • #145
hmmmm i believe I am doing the exact same question! I am just as stuck, i was under the impresion that you simply hook up a curcit with a powersource, the photocell and reviver thing (is that the diode?) and an ammeter, then alter the distances and ,easure the current.
am i any where near right?
