Will a Rock Thrown Upward Reach the Top of a Castle Wall?
  • Thread starter Thread starter BeckyStar678
    Fall Free fall
The discussion centers on a physics problem involving projectile motion, specifically analyzing the trajectory of a rock thrown upward from a height of 1.55 m towards a castle wall 3.65 m high with an initial speed of 7.40 m/s. The calculations indicate that the rock does reach the top of the wall, taking approximately 9 seconds to do so, and its speed at the top is calculated to be 2.4 m/s. Additionally, the discussion raises questions about the change in speed of a rock thrown downward from the wall's height and whether it aligns with the upward motion's speed change.
  • Understanding of kinematic equations, specifically the equation xf=xi+vxit+1/2axt²
  • Knowledge of gravitational acceleration, typically -9.80 m/s² on Earth
  • Familiarity with concepts of projectile motion and energy conservation
  • Basic algebra skills for solving equations
  • Review kinematic equations for projectile motion in detail
  • Study the concept of energy conservation in vertical motion
  • Learn how to calculate time of flight for projectile motion
  • Explore the effects of initial velocity on the trajectory of projectiles
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of projectile motion and kinematics in real-world scenarios.
BeckyStar678
an attacker at the base of a castle wall 3.65 m high throws a rock straight up with the speed 7.40 m/s at a height of 1.55 m above the ground. a.) will the rock reach the top of the wall? b.) if so, what is its speed at the top? if not, what initial speed must it have to reach the top? c.) find the change in speed of a rock thrown straight down from the top of the wall at an inital speed of 7.40 m/s and moving between the same two points. d.) does the change in speed of the downward-moving rock agree with the magnitude of the speed change of the rock moving upward b/t the same elevations? explain physically why it does or does not agree
xf=xi+ vxit+1/2axt2
so for the first question, what i did was plug in the data for the above equation (making acceleration -9.80) and getting the time which is 9 seconds. so i took that as yes it does reach the top after 9 seconds, because i put xf as 3.65. so then i took the 9 seconds and plugged it in the equation and got 2.4 as the speed at the top. and then i don't know what to do for c.
Hi BeckyStar678,
xf=xi+ vxit+1/2axt2
I don't believe this is correct; can you show how you got this result (what numbers you used and how you used them in the equation).
  • · Replies 35 ·
