What causes water to oscillate at high temperatures in the Leidenfrost effect?
  • Thread starter Tamerlane
In summary: Suface tension created by the dipole-dipole attraction of water molecules are the reason for this. however, you may want to try a chemistry forum for the answer.Is this the definition?LEIDENFROST EFFECT - Where a liquid will not wet a surface and becomes insulated from the surface by a layer of vapor if the surface is above a critical temperature of the liquid. The surface is usually well above the liquids boiling point. Water beads seems to last forever in a 400 F frying pan on a stove, where they would boil away in 5 seconds if the pan were only 220 F. McGraw Hill, Dic. of Sci. and Tech. Terms, 5th ed, 1994 (200,
Tamerlane
First of all, let me say that I'm a french [in the way that i speak french] student and most probably my sentences will not be as accurate as they should, excuse me in advance.
To make a long story short, the Leidenfrost effect makes a water drop to stop "boiling" at temperatures higher than 240 Celsius. The principle is as follows: the suddent heating of the water (when it falls on the surface) immediately creates a vapor layer between the liquified water and the surface.
Note: we have roughly measured the actual temperature of the water at around 80 celsius.
The same effect happens with a particular plastic surface that as been "polished" (or scratched) with an extremely thin sandpaper OR a surface covered with teflon => there is small "bubbles" of air that gets trapped between the real surface and the water.
Anyway, what interests me and my group is that when you heat the water ; our optimal temperature (for the oscillating mode we concentrated on) is about 410 celsius, at that point and from a very particular volume of water [the drop constantly evaporate], it starts oscillating at a frequency of about 10Hz and increasing. At that point, the drop has a rounded triangular shape, but it's so fast, you see 6 and arguably 8 tip to the "star" it forms.
Now, i'd like to know if anybody has ever heard of or work on such thing, we'd especially like to know what exactly happens, what makes the water turn on itself or oscillate [we're not even sure about the movement of the molecules within the drop]. If there is any formula that exists to describe such phenomenon or anything else.
Also, we are being told it has something to do with surface tension, anyone can help?
Thank you
Salut,
I have never heard of such a thing! But I will ask my colleagues about it. I think your english is excellent by the way.
LEIDENFROST EFFECT - Where a liquid will not wet a surface and becomes insulated from the surface by a layer of vapor if the surface is above a critical temperature of the liquid. The surface is usually well above the liquids boiling point. Water beads seems to last forever in a 400 F frying pan on a stove, where they would boil away in 5 seconds if the pan were only 220 F. McGraw Hill, Dic. of Sci. and Tech. Terms, 5th ed, 1994 (200,000 definitions in one book)
Thought posting the definition I use in my book "Effects and Their Uses" should be included here.
Steve Stillman
Steve: well...i already know that, I've been looking at those water beads for hours, but thanks anyway
2Pac: hmm...dipole-dipole attraction, that might be the answer...but do you think that would be enough to create a cross wave [now I'm really not sure if it's the right word, in french it's called "onde transversale" where onde = wave] and we observed 6 different modes of oscillation, we are currently studying the 4th mode because it's the one that we have the most facility to recreate
You are more likely looking at "vortex shedding" from a "bluff body" --- sorry, no French translation for you.
hmm, that sounds interesting, i'll look for that :)
mmwave said:
Salut,
Well, one physics prof. said "I remember hearing of it but forget what it is" ,when I described it per your post he said "oh that sounds right". The other had never heard of the term Leidenfrost effect but when I described it said "oh yeah, I remember learning about that" but neither could point me to a reference for more information. He also said it's the same effect that makes drops of liquid nitrogen dance on the floor or a table top, unless it's a layer of dust that gathers around the surface of the drop instead.
What is the Leidenfrost effect?
The Leidenfrost effect is a phenomenon in which a liquid, such as water, placed on a surface significantly hotter than its boiling point will create a vapor barrier that prevents it from boiling immediately. Instead, the liquid will form droplets and skid across the surface, creating a unique sizzling sound and leaving behind a characteristic trail.
How does the Leidenfrost effect work?
The Leidenfrost effect occurs because the extremely hot surface causes the bottom layer of liquid to rapidly vaporize, creating a layer of gas between the liquid and the surface. This layer of gas acts as an insulator, reducing the rate of heat transfer and preventing the liquid from boiling. This effect is strongest when the surface temperature is around 300°C.
What factors affect the Leidenfrost effect?
The Leidenfrost effect can be influenced by several factors, including the temperature of the surface, the properties of the liquid, and the surface roughness. Higher surface temperatures and smoother surfaces tend to enhance the effect, while lower surface temperatures and rougher surfaces can make it more difficult to observe.
What are the practical applications of the Leidenfrost effect?
The Leidenfrost effect has several practical applications, including in cooking and industrial processes. In cooking, the effect can be utilized to determine the temperature of a hot surface, such as a frying pan or griddle. In industry, it can be used to create a vapor barrier to protect delicate materials from high temperatures during manufacturing processes.
Is the Leidenfrost effect dangerous?
The Leidenfrost effect is not inherently dangerous, but it can pose a risk if proper safety precautions are not taken. For example, if a person's skin comes into contact with a surface experiencing the Leidenfrost effect, they may not feel the heat and could suffer from burns. It is important to handle hot surfaces with caution and proper protective gear to prevent any potential hazards.
  • Classical Physics
  • Mechanics
