Help on this would be amazing; centripetal force & projectile motion
The discussion revolves around a physics homework problem involving centripetal force and projectile motion related to David using a sling. Key calculations include determining the launch velocity, centripetal force, and the distance from David to Goliath. Participants clarify that the angular speed calculated from the sling's rotations is not the same as the launch speed, which is the tangential speed at the point of release. The relationship between angular speed and tangential speed is emphasized, aiding in the correct approach to the problem. Overall, the conversation highlights the importance of understanding the distinctions between different types of speeds in circular motion.
dominus96
David used a sling to kill Goliath. The mass of the rock was 2.5 kg and the sling had a length of 1.2 m. If it spun horizontally 2 m above his head 7 times in 3 seconds:
a. What was the launch velocity?
b. What is the centripetal force and tension?
c. How far is David from Goliath?
Fc=mv^2/r
F=ma
Fc=m4(pi^2)r/t^2
I tried setting ma=mv^2/r, but that would only give me the velocity it spins at, not the velocity at which it was launched. And I'm not sure what to do with the 2 m.
Assistance would be great, I've been trying this for 2 hours and still nothing.
7 times in 3 seconds gives you the angular speed, which will also be the launch speed. We assume it was rotating about David's head at a constant rate.
From the angular speed you have calculated, you can get the centripetal force. This must equal the tension
For c. you need to use the equations of motion, which is where the 2m comes in
Thank you
dominus96 said:
Thank you
I am a little rusty, but I am quite sure that the launch speed does not equal the angular speed. The rock leaves the sling's cirular path in a direction perpendicular to the string.
Angular speed=\omega launch speed=v_{tangential}
Do you know of a relationship between angular and tangential speed?
Casey
ah crap, yes, i meant the tangentil speed, lol.
Yes i figured that out, but thanks for the lead. it helps a lot.
