Help Problem on INCLINED planes.
The discussion centers on calculating the acceleration of a system involving two masses connected by a rope over a frictionless pulley on an inclined plane. The user initially derived an acceleration of 3.3 m/s² but found discrepancies with the provided solution, which states the acceleration is 4.5 m/s². The confusion arises from the signs used in the equations, particularly regarding the frictional force opposing motion. It is confirmed that the signs in the accepted solution are incorrect, leading to the wrong calculation of forces. The user is advised to ensure that friction is always considered as opposing the direction of motion.
byronsakic
Hello, here is the question.
Two masses, 4.0 kg and 6.0 kg, are connected by a “massless” rope over a “frictionless” pulley as pictured in the diagram. The ramp is inclined at 30.0º and the coefficient of kinetic friction on the ramp is 0.18.
http://www.clickandlearn.org/Physics/SPH4U/tests/ch2_test_files/i0430000.jpg
(b) Determine the acceleration of the system once it begins to slide.
i only need help on b.. finding the acceleration. if i can get the right acceleration i can get all the other parts.
Now i solved it by doing this. making 2 equations.
4 kg = m1 6kg = m2 motion to the right is positive. uk = 0.18
m1a = T - [Ff + Fg||]
m1a = T - (uk)(m1g)cos30 - sin30m1g
m1a = T - 6.1 - 19.6 equation 1
m2a = m2g - T
m2a = 58.8 - T equation 2
add the two equations together you get. (T cancel out)
a (m1 + m2) = 58.8- 25.7
a = 33.1 / 10
a = 3.3 m/s ^2
i have been lookin over my calculation over and over and the acceleration is different from the answers.
here is the SOLUTION:
(b)
For the 4.0-kg mass:
http://www.clickandlearn.org/Physics/SPH4U/tests/ch2_test_files/a0430000.jpg
4.0 kg(a) = T – uKmg(cosX) – mg(sin X)
4.0 kg(a) = T – 13.5 N
For the 6.0-kg mass:
http://www.clickandlearn.org/Physics/SPH4U/tests/ch2_test_files/a0430001.jpg
6.0 kg(a) = 58.8 N – T
Solving the system of equations:
a = 4.5 m/s2
according to the solution... for equation 1.. it is + 6.1 - 19.6 = -13.5
but it doesn't make sense because it should be -6.1 - 19.6 = -25.7
is there a trick I am missing or do you think the solution is wrong? this question is vital for a test on monday.
thank you
byron
You are correct, friction always opposes motion. The signs used in the accepted solution are wrong.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
