Help Solving/Creating a Question
  • Thread starter Thread starter atOnz
Superman needs to exert enough force to pull a train weighing 395,300 kg up an inclined plane of 15 degrees while overcoming friction and the train's opposing force. The calculations reveal that he must overcome a total force of 3,292,767 N, which includes gravitational force, friction, and the train's applied force. To determine the power output required from Superman, the formula P = Fv can be used, where v is his walking velocity. The discussion highlights the importance of understanding the difference between force and power in physics. The calculations ultimately illustrate Superman's immense strength in comparison to conventional locomotives.
atOnz
I need to prove how Superman would 'be more powerful than a locomotive.'
http://img221.imageshack.us/img221/5408/diagram8gm.th.jpg
From my diagram I need to find out how much power Superman has to put out to be able to pull that train up the track. I know he has to pull the train 8.5m on an inclined plane of 15 degrees.
-I know the train has a mass of 395 300kg.
-I also know the train is applying a force in the opposite direction.
-Coefficient of kinetic friction of a steel on steel is 0.57
-And finally I know the train is putting out 2,387,200W (3, 200hp) to make that applied force.
So Superman has to overcome the FApplied(train) + FFriction + Fgx to be able to pull the train.
-FN = mgcosx = (395300kg)(9.81m/s^2)(cos15) = 3745757N
-uk = FFriction/FN
FFriction = (0.57)(FN) = 2135081N
-Fgx = mgsinx = (395300kg)(9.81m/s^2)(sin15) = 1003673N
Okay so I found FFriction and Fgx of the train but I still need the FApplied by the train to know how much force superman needs to apply in the opposite direction to move it up the hill.
I know the train is putting out 2,387,200W of power in the opposite direction. But how can I calculate how much force that is? Maybe I misunderstand the difference between force applied and power?
Please help me in anyway possible.
-Jay
Assuming constant velocity, you can use the equation P=Fv, where v is velocity. Remember that F and v are vectors.
So I researched that this train can get up to at most 56km/h (15.5m/s). I guess the easiest thing to do is assume it's constant because well, to do otherwise might be out of my current level of physics education :P.
2, 387, 200W = F(15.5m/s)
F=154013N
So superman has to overcome Fgx (1003673N) + FFriction (2135081N) + FApplied(train) (154013N) = 3292767N?
Then I guess I can use P = mv again once I find the average velocity a person walks with, to find how much power Superman puts out?
Yep, that's some strong biceps there :biggrin:
That is the expression for momentum. If you mean to use P = mgv, then no you can't. The force of gravity and the velocity are perpendicular to each other and hence are independant. However, you could work out his power output using P = 3292767v, where v is his walking velocity.
Oh my, sorry for that! I meant P=Fv. Thank you for your help!
My pleasure :smile:
