Stress Strain Problem: Finding the Final Length
  • Thread starter Thread starter Saladsamurai
    Strain Stress
The discussion revolves around calculating the final length of a material after stress is applied and then removed, focusing on the distinctions between elastic and plastic strain. The initial calculations incorrectly treated plastic strain as a proportion rather than an absolute value, leading to discrepancies in the final length. The correct approach involves first determining the total change in length using total strain and then calculating the elastic recovery to find the final length. The participants clarify that the total change in length is indeed based on the total strain multiplied by the original length, with plastic strain contributing to the final length after elastic recovery is accounted for. Ultimately, understanding the definitions and relationships between different types of strain is crucial for accurate calculations.
Saladsamurai
HELP! Stress Strain Question
In part (a) of the problem, we found that due to a certain stress, the amount of
elastic strain that a material undergoes is
\epsilon_E=.0087
and the amount of plastic strain is
\epsilon_{pl}=.0113.
The total strain is therefore
\epsilon_T=.02We are then told that a sample of this material with original length
l_o=610 \ mm undergoes that same stress involved in part (a).
What is the new length l_fafter the stress is removed ?So I believe the idea behind this is that we gain the elastic portion of the strain back, but the plastic elongation should be added onto the original length.
I wrote this quantitatively as:
l_f=l_0+\epsilon_{pl}\Delta l (1)
To find the change in length we have:
\epsilon_T=\frac{\Delta l}{l_0} \Rightarrow \Delta l=\epsilon_Tl_0 (2)
Therefore (1) becomes:
l_f=l_0+\epsilon_{pl}(\epsilon_Tl_0)
\Rightarrow l_f=l_0(1+\epsilon_T\epsilon_{pl})
Plugging in numbers we have lf=.6101 mm
but the correct answer is .6167 which is waayyy off.
What am I missing here?
First find the length when the total load is applied (i.e., the length incorporating elastic and plastic strain). Then find the length change associated with elastic recovery of this sample, and subtract this.
I will try that. But how is that different? What concept am I missing here? I do not see the difference between adding the plastic elongation to the initial length and subtracting the elastic elongation from the final length.
The mistake you made originally was taking \epsilon_{pl} as the proportion of plastic strain, rather than the amount of plastic strain. The product \epsilon_T\epsilon_{pl} doesn't have any meaning in this problem.
Personally, I think an answer of l_f=l_0(1+\epsilon_{pl})=0.6169[/tex] is good enough and simpler. But the approach I described gets you to .6167 (actually .616786), so perhaps it's the approach intended by the person who wrote the problem.
I don't understand this statement?
It was given that this was the plastic strain:confused:
Edit: hold on... let me think...
Nope... I still don't understand. If by definition strain is \epsilon_T=\frac{\Delta l}{l_0} then isn't it by definition a proportion?
i.e., percent change in length.
In your equation (1) you've multiplied strain by change in length. This doesn't mean anything; strain is already change in length divided by original length. The term \epsilon\Delta L just isn't useful or meaningful here.
However, you could calculate that
\epsilon_{pl}/ \epsilon_T=\epsilon_{pl}/(\epsilon_{pl}+\epsilon_{E})=56.5%
of the total strain is plastic, and multiply this percentage by the total change in length to get the plastic change in length. That's what I meant by the proportion of plastic strain.
Okay. I kind of follow you now. But what is the total change in length is it not \epsilon_{tot}*l_o ?
So my original (1) should have been:
l_f=l_0(1+\frac{\epsilon_{pl}}{\epsilon_{tot}})
arrgggg goddamn Latex
Yes, that's the total change in length. Did I say something different?
I don't know :smile: Perhaps I did! I hate this class! Thanks for the help!
Just keep at it and soon it'll seem easy. Good luck.
