Help understanding pressure involving water in two different cylinders
The discussion revolves around understanding the pressure dynamics involved in moving water into different types of tanks through varying pipe sizes. Participants explore the implications of hydrostatic pressure and flow resistance in a natural gas context, specifically comparing a wide tank with water to a narrower pipe system.
  • One participant questions whether it requires more pressure to inject water into a 12ft wide tank with 12ft of water or to run a 3-inch pipe up the side of a 20ft tank and dump water in at the top.
  • Another participant asserts that hydrostatic pressure is determined solely by the depth and density of the fluid, indicating that the area of the fluid container does not affect hydrostatic pressure.
  • A participant inquires if using a smaller pipe would require less pressure to displace a given amount of water into the tank.
  • One participant argues that a larger 3-inch pipe will have less flowing friction back pressure and a higher flow rate compared to a 1-inch pipe for the same flow rate.
  • It is noted that as fluid velocity increases in a pipe, the flowing backpressure also increases, suggesting that larger pipes may facilitate lower backpressure.
Participants express differing views on the relationship between pipe size, flow resistance, and pressure requirements. There is no consensus on the implications of using different pipe sizes for water displacement.
Participants discuss various factors influencing pressure and flow, including hydrostatic pressure, friction, and flow rate, but do not resolve the complexities of these interactions.
Branson Sutter
Please excuse my ignorance. I work for a Natural gas company and have an issue that needs addressed. When gas comes out of the ground it goes into a piece of equipment that separates the water from the gas. The gas goes into a pipeline and the water is dumped into a tank. We are currently trying to figure out which application would have less resistance. So the question is would it require more pressure to inject the water into the bottom of a 12ft wide tank with 12ft of water in it, or to run a 3inch pipe up the side of the 20ft tank and dump the water in at the top. One person claims that the hydrostatic pressure will be higher in the 20ft 3inch section of pipe when full of water vs the 12ft wide tank with 10 ft of water. I don't know enough about this but I figure there are multiple measures of pressure/resistance involved so figured I would ask someone smarter than myself. Thanks
Branson Sutter said:
One person claims that the hydrostatic pressure will be higher in the 20 ft 3 inch section of pipe when full of water vs the 12 ft wide tank with 10 ft of water.
That person is correct. Only the depth and density of a fluid determines its hydrostatic pressure.
The area of fluid container has no effect, the hydrostatic pressure at a given difference in elevation is the same for a giant lake as it is for 0.10 inch diameter tube.
Thank you! the water is being moved to the tank by the pressure from the well. Would running smaller pipe, lowering the volume of water, require less pressure to displace any given amount of water into the tank?
I think maybe a better way of asking would be. Is there more resistance, from friction or any other source, to push 10 gallons of water through a 3 inch line full of water vs a 1 inch line full of water the same length
No, it is exactly the reverse, the larger 3" pipe will have less flowing friction back pressure and a higher flow rate for a given pipe inlet pressure than the 1" pipe.
For any given flow rate (gpm etc) through a pipe, as the velocity of the fluid flowing through the pipe increases, the pipe's flowing backpressure increases; so, the pipe with the largest inside area will have the lowest flow velocity and therefore the lowest flowing backpressure.
  • · Replies 20 ·
12K
  • · Replies 39 ·
18K
