Where Did I Go Wrong With Undetermined Coefficients for y+y'+4y = 2sinh(T)?
SoulofLoneWlf
i solved homogenous but
y"+y'+4y = 2sinh(T)
is giving me trouble
also have a hint
sinh t = (e^t - e^-t)/2
also my "guess" was
aE^t +Be^-t=Y
maybe my guess was wrong?
That should be fine.
Why are you asking? Have you tried putting that into the equation? If you are used to working with hyperbolic functions directly, you can also use y= C cosh(t)+ D sinh(t).
tried this guess but yield wrong answer guess ill do a few more times thanks all
In the "Homework" forum, you can put in your work with wrong answer, and ask where you went wrong.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
