Help with 1st order non linear ODE
  • Thread starter Thread starter strohm
    Linear Ode
strohm
y = y' (1+t^{4} +y^{8}+t^{2}y^{2})
y(0) = 0
I tried separating the variables, but it doesn't work.
Thanks in advance.
Hm, can someone tell my why that when I tried to solve this DE with Maple to see if it had an exact solution, Maple just threw me a blank? When I tried again, it doesn't even pause but just goes straight to the next command line, as if he executed it without showing any result (and I've double and tripple-checked my symbols, no errors there)
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
