Help with 2nd order differential equations needed
5 replies · 2K views
Brewer
I have come across the following question when revising for my upcoming exam, and wondered if anyone wouldn't mind giving me a hand and some hints as how to solve it.
A car of mass m is moving on a road. The car engive provides a moving force [tex]F_{m}[/tex]. The frictionalforce is proportional to the speed, v, of the car: [tex]F_{f} = kv[/tex]. Write down Newtons Second Law as a second order differential of the motion of the car. Solve this equation to find the distance, s, from an initial point as a function of time, t, assuming initial conditions s(0)=0 and v(0) = 0
So far I have:
[tex]F_{m} - k\frac{ds}{dt} = m\frac{d^2s}{dt^2}[/tex]
And now I'm stuck as to the solution of the equation, as its a 2nd order non-homogenous differential equation, but doesn't have a term in s. Is this a problem when solving this, or do I just put it =0?
Any hints would be appreciated!
Apologies if the symbols don't come out as anticipated. Its my first time using them!
Make the substitution,
[tex]v(t)=\frac{ds}{dt}\mbox{ so that }\frac{dv}{dt}=\frac{d^2s}{dt^2}[/tex]
and the DE becomes a first order, namely
[tex]F_{m} - kv = m\frac{dv}{dt},[/tex]
that you can solve. Once you have a solution for v, plug it into [tex]v(t)=\frac{ds}{dt},[/tex] and that'll give you the solution to the given DE. Note that we didn't turn a second order DE into a first order DE, but rather a system of 2 first order DEs.
That thought had occurred to me, however the answer I got for v made no sense.
I ended up with the following processes:
[tex]f_{m} - kv = m\frac{dv}{dt}[/tex]
[tex]\int dt = m\int\frac{dv}{F_{m} - kv}[/tex]
[tex]t=\frac{-m}{k} \ln(F_{m} - kv) + c[/tex]
which I then rearranged to make v the subject. However I don't think that this is correct way to do this is it? I think I probably used the wrong technique when integrating?
Here it goes...
Rearrange the DE to be
[tex]\frac{dv}{dt}+\frac{k}{m}v =\frac{f_{m}}{m}[/tex]
Then the associated homogeneous equation is
[tex]\frac{dv}{dt}+\frac{k}{m}v =0,[/tex]
Put [tex]v(t)=Ae^{\lambda t}\mbox{ so that }\frac{dv}{dt}=A\lambda e^{\lambda t}[/tex] and this, when substituted into the homo. eqn., gives
[tex]A\lambda e^{\lambda t}+\frac{k}{m}Ae^{\lambda t} =0[/tex]
or [tex]Ae^{\lambda t}\left( \lambda +\frac{k}{m}\right) =0[/tex]
and since [itex]e^{\lambda t}\neq 0[/itex] for any t, we have
[tex]\lambda +\frac{k}{m} =0\mbox{ and hence }\lambda =-\frac{k}{m}[/tex]
which gives [tex]v_H(t)=Ae^{-\frac{k}{m}t}[/tex] as the general solution to the associated homogeneous equation.
Now, since the non-homogeneous equation, namely
[tex]\frac{dv}{dt}+\frac{k}{m}v =\frac{f_{m}}{m},[/tex]
differs only by a constant term, let us solve for an arbitrary constant as a particular solution, say [tex]v_P(t)=B[/tex], whose derivative is 0, and it must satisfy
[tex]0+\frac{k}{m}B =\frac{f_{m}}{m},[/tex]
so [tex]B =\frac{f_{m}}{k}=v_P(t),[/tex] and hence the most general solution to the given DE (the one in v) is [tex]v(t)=v_H(t)+v_P(t)[/tex], that is
[tex]v(t)=Ae^{-\frac{k}{m}t} + \frac{f_{m}}{k},[/tex]
The initial condition is v(0) = 0, from which we can determine A:
[tex]v(0)=A\cdot 1 + \frac{f_{m}}{k}\Rightarrow A=-\frac{f_{m}}{k}.[/tex]
Thus the solution for v is
[tex]v(t)=-\frac{f_{m}}{k}e^{-\frac{k}{m}t} + \frac{f_{m}}{k}=-\frac{f_{m}}{k}\left( e^{-\frac{k}{m}t}-1\right)[/tex]
but recall we had made the substitution
[tex]v(t)=\frac{ds}{dt}[/tex]
so...
Thank you. That helped a lot. I think I actually was on the right lines, I'd just confused myself, but your way seems to make a lot more sense to me.
Thanks again
The above way is only so lengthy as I explained the means by which the technique is derived...
Note that from
[tex]-\frac{k}{m}t-c= \ln(F_{m} - kv)[/tex]
[tex]v(t)=\frac{F_{m}}{k}-\frac{1}{k}e^{-\frac{k}{m}t-c} =\frac{F_{m}}{k}-\frac{1}{k}e^{-\frac{k}{m}t}e^{-c}[/tex]
and then reason that [tex]e^{-c}=A[/tex] for some positive A... same answer as mine, if you follow it out.
