Help with a Simple Harmonic Motion problem
A 25.0g bullet strikes a 0.600kg block attached to a spring, causing it to vibrate with an amplitude of 21.5cm. The spring constant is 6.70x10^3 N/m, and the combined mass of the block and bullet after impact is 0.625kg. The calculated velocity of the block and bullet together is 22.26 m/s, but the correct speed of the bullet before impact is 557 m/s. To find this, conservation of momentum must be applied, equating the bullet's momentum before impact to the combined momentum after impact. The discussion emphasizes the importance of using momentum conservation to solve for the bullet's speed accurately.
ceeforcynthia
1. A 25.0g bullet strikes a .600kg block attached to a fixed horizontal spring whose spring constant is 6.70x10^3 and sets it into vibration with an amplitude of 21.5cm. What is the speed of the bullet before impact if the two objects move together after impact?2. V=A\sqrt{k/m}
3. I used the equation above, adding the masses together (.625kg). I got the velocity to be 22.26m/s... but now i can't figure out how to get the speed of the bullet.
The answer in the book says that the speed of the bullet is 557m/s.
2. V=A\sqrt{k/m}
Use conservation of momentum. momentum of the bullet before the impact = momentum of the block plus bullet moving together at 22.26 m/s
