Algebraic Equations for Basic Tension in a Hanging Block System
  • Thread starter Thread starter shotgunbob
The discussion focuses on solving for the tensions in a hanging block system with a 5 kg block, where one side of the string is at a 30-degree angle and the other at 45 degrees. The equations derived include T1(cos 30) - T2(cos 45) = 0 for the x-direction and T1(sin 30) + T2(sin 45) - 50 N = 0 for the y-direction. Participants suggest rearranging the equations to express T1 in terms of T2, leading to T1 = T2(cos 45)/(cos 30). The conversation emphasizes using algebraic manipulation to isolate one variable and solve the system of equations effectively. The goal is to accurately determine the tensions in the system.
shotgunbob
Basic Tension question- 5 kg block hanging from a string with one side at 30 degrees and the otherside at 45 degrees.
Fnet,x=t1x-t2x=0
Gravity assumed at 10 m/s2 (in the book)
I got to:
T1(cos 30)-T2(Cos45)=0 for the total forces in the x direction and
T1(sin 30) + T2(sin 45)-(50 N)= 0 for the y direction
I know I am supposed to use algebra but i never was very good with numbers. How I got into AP physics, I'll never know! Thanks in advance!
doing good. you have two unknowns in one equation. how about some rearranging to evaluate for one T and using some substitution?
Hint: What is T1 equal to? (not asking for the tension value)
hmmm t1= t2 (cos 45)/cos 30)
So now I have T2((cos45)/(cos30))-T2Cos45
For which I get .8164965809 hmmmmm where did i go wrong
Close, but not quite. You're right:
T1 = T2(cos45)/(cos 30)
now take this and use it for the T1 in the other equation, then solve for T2. You should be good to go.
