Help with Array: Evaluating Integral of sin(x)
  • Thread starter Thread starter 999iscool
    Array
The discussion revolves around writing a program to evaluate the integral of sin(x) using the left-hand rectangle rule across ten specified intervals. The program should store the results in an array of type double, with each element representing the integral result for the respective interval. The output should consist of these ten results, with an example showing that result[0] for the interval [0, 1) should be approximately 0.4597. Participants clarify the method of calculating the integral, emphasizing the use of left endpoints rather than right-hand rules. A sample code snippet is provided, demonstrating the integration process with a defined width for subintervals. Suggestions are made to optimize the code, such as simplifying the integrand function and creating a separate function to handle the integration calculations for each interval. The importance of confirming the accuracy of the results is highlighted, as discrepancies in outputs from classmates are noted.
999iscool
You will write a program that evaluates the integral of sin(x) using the left-hand rectangle rule with
2000 subintervals, over 10 intervals. The intervals to test are [0, 1), [1, 2), …, [8, 9), [9, 10). You will
declare an array of type double that can hold 10 elements, and you will use this array to hold all 10
results you get from evaluating each interval.
What I need help with is the output.
What should be our output?
For example, [0, 1) ?
Technology news on Phys.org
The output should be the 10 elements in the array. Each array element is the number you get from integrating sin(x) on one of the intervals.
For example, result[0] should have a number that is close to -.5403.
Edit: that should be .4597.
How did you get that number? I thought plain riemann sum (in this case, the right hand rule)
Here is the short version (with no array), tested [0,1)
Code:
#include <iostream>
#include <cmath>
   using namespace std;
double integrand(double);
int main()
	const int SIZE = 10;
	const double WIDTH = 0.0005;  // (b-a)/n
	double sum_array[SIZE];
	double a = 0.0;
	double b = 1.0;
	double sum = 0.00;
	double y1 = 0;
	for (double k = a; k < b; k += WIDTH)
		y1 = integrand(k);
		sum += y1;
	cout << (sum*WIDTH) << endl;
	return 0;
double integrand(double x)
	double y;
	y = sin(x);
	return y;
edited the code again (added (sum*WIDTH). I forgot about this)
I got 0.45968 for [0, 1) using left endpoint
Forgot to add 1. Make that .4597.
LOL
OKay, so it is 1-cos(1) for [0, 1)
Just really need to confirm that. Otherwise, even if I have perfect codes, with no REAL solution i still can't test it.
My other classmates are giving me weird numbers.
Thanks
Your first post says to use the left endpoints.
Code:
#include <iostream>
#include <cmath>
int main()
	double a = 0.0;
	double b = 1.0;
	double sum = 0.00;
	double y1 = 0;
		y1 = integrand(k);
		sum += y1;
	return 0;
	double y;
	y = sin(x);
	return y;
Yeah, that's what you should get.
Some suggestions. Your integrand function can be shortened.
Code:
    return sin(x);
Also, you could write a function that does essentially what you do in main. It should take three parameters: left endpoint, right endpoint, number of subintervals, and should return the computed value for that interval. The 10-element array would still be in main -- just loop through each element in the array and call your calculating function for each of the intervals 0 - 1, 1 - 2, ... 9 -10.
Thread 'Star maps using Blender'
Blender just recently dropped a new version, 4.5(with 5.0 on the horizon), and within it was a new feature for which I immediately thought of a use for. The new feature was a .csv importer for Geometry nodes. Geometry nodes are a method of modelling that uses a node tree to create 3D models which offers more flexibility than straight modeling does. The .csv importer node allows you to bring in a .csv file and use the data in it to control aspects of your model. So for example, if you...
I tried a web search "the loss of programming ", and found an article saying that all aspects of writing, developing, and testing software programs will one day all be handled through artificial intelligence. One must wonder then, who is responsible. WHO is responsible for any problems, bugs, deficiencies, or whatever malfunctions which the programs make their users endure? Things may work wrong however the "wrong" happens. AI needs to fix the problems for the users. Any way to...
