Help with Error in gravity due to uncertainty in r.
The discussion focuses on deriving an algebraic expression for the error in gravity (g) due to uncertainty in the radius (r), using limit error formulas while assuming negligible errors in gravitational constant (G) and mass (M). Participants emphasize the importance of clearly showing all steps in the calculations to identify misconceptions or errors. There is a request for users to share their attempts to facilitate better guidance. The conversation highlights the need for clarity in applying the error formula correctly. Overall, the thread aims to assist in understanding how uncertainty in r affects the calculation of gravity.
cam borrett
Derive an algebraic expression for the error in gravity due to the uncertainty in r. Use limit error formulas and show all steps. Assume that errors in G and M are negligible.
g=GM/r^2
[/B]
i use the error formula but not sure about what the input for what...
Show us what you did. It is the absolutely easiest way for us to identify where you are going wrong or where your misconception lies.
