Help With Infinite Exponential Limit
alba_ei
<br /> \lim_{x \to - \infty} \frac{3^x-3^{-x}}{3^x+3^{-x}}<br />
<br /> \lim_{x \to - \infty} \frac{3^x-3^{-x}}{3^x+3^{-x}} = - 1<br />
Im getting trouble when I try to evaluate this limit, altough the answer is -1 idont know how to get to it.
<br /> = \lim_{x \to - \infty} \frac{3^{-x}(3^{2x}-1)}{3^{-x}(3^{2x}+1)}<br />
<br /> = \lim_{x \to - \infty} \frac{3^{2x}-1}{3^{2x}+1}<br />
<br /> = \lim_{x \to - \infty} \frac{1-\frac{1}{3^{2x}}}{1+\frac{1}{3^{2x}}}<br />
<br /> = \lim_{x \to - \infty} \frac{1}{1} = 1<br />
I got 1, not -1
How did you get +1?
you can do an algebraic trick to get that \frac{3^{x}-3^{-x}}{3^{x}+3^{-x}}=\frac{3^{2x}-1}{3^{2x}+1} and then the limit is trivial.
I'm not sure how you got from the left hand side to the middle of your solution. Could you explain your steps further?
remember that when you take the limit of an exponential when the variable tends to -\infty you get that this limit is 0. And remember that 3^{2x}=e^{2x\ln{3}}
Does 1/3^{2x} ---> 0 as x ---> -Infinity?
I think I messed up my reply by not quoting anyone, and now you've edited and put in more of your solution! Anyway...
There is no need to do this step. You should note that, since we are taking the limit x tends to negative infty, 3^2x tends to zero.
I got 1, not -1
