hayowazzup
- 63
- 0
Does anyone know how to measure the input and output impedance of a bjt circuit on Ltspice? eg. a circuit like this
The discussion focuses on measuring the input and output impedance of a BJT circuit using LTspice, exploring various methods and considerations for accurate measurements. Participants discuss the implications of circuit configurations, component values, and analysis types, including AC and transient analysis.
Participants express a range of views on the methods for measuring impedance, with no clear consensus on the best approach. There are competing suggestions regarding component values and circuit configurations, and some participants report differing results based on their setups.
Limitations include the dependence on specific circuit configurations and component values, as well as the potential impact of reactive components on measurements. Some participants note that changing the circuit alters the problem being addressed.
This discussion may be useful for electronics enthusiasts, students learning about circuit analysis, and engineers interested in practical applications of LTspice for impedance measurement.
Exactly.vk6kro said:You have real gain if the power of the output is greater than the input. This is the case with most transistor amplifiers. You compare this to a transformer where the power out cannot be more than the input.
Correct, but the product of the voltage gains of the individual stages can never be greater than beta^n where n is the number of stages and the output impedance is equal to the input impedance.vk6kro said:For example, you could follow a voltage gaining common emitter amplifier with an emitter follower.
You have high input impedance followed by a low output impedance. You could cascade these modules as much as you like or until the noise from the first stage is amplified enough to be objectionable.
True, but I would prefer to use a different term for voltage gain due only to impedance transformation. For instance the familiar 20*Log(Vout/Vin) does not apply in those cases and I don't think this is made clear in many EE classes.vk6kro said:Cascading stages is not the only reason to build an amplifier. You may want to drive a meter or a lamp or close a relay. You could drive a FET or the input of an oscilloscope or a frequency counter.
