What Formulas Should I Use to Calculate the Speed of an Object Before Impact?
  • Thread starter Thread starter laker_gurl3
    Force Physics
The discussion focuses on calculating the speed of a 25 kg object before impact when released from a height of 8.9 million meters above the Earth's center. Participants emphasize using the Conservation of Energy principle, equating gravitational potential energy at the initial height to kinetic energy just before impact. The gravitational potential energy (GPE) is calculated using the formula mgh, with adjustments for gravitational field strength at different heights. There is a reminder that mgh is only valid for heights significantly smaller than the Earth's radius, and users are encouraged to start new threads for unrelated questions. The conversation highlights the complexities of gravitational calculations in physics.
laker_gurl3
help with physics! grav force
hello can someone help me on these questions?
i just need help with which formulas to use, i could not get any answer at all.
a stationary 25 kg object is released from a position 8.9x10^6m from the center of the earth. what's is the speed of the object before impact?
Apply Conservation Of Energy.Before and after the impact.
Initially Total Energy: - \frac {GMm}{x}
Final Energy : - \frac {GMm}{R} + \frac{1}{2}mv^2
Equate above and Solve.
BJ
I am a year 12 student so please bear with me - I could be horribly wrong.
PS: this is my first post on this forum!
You need to figure out the change in gravitational potential energy from the height you gave, to the surface of the earth.
You need to know that
the formula for for grav. potential energy is given by mgh
radius of Earth is 6.3*10^6m ( I think? )
gravitational field strength of Earth is given by GM/(R^2)
Lets figure out the G part of mgh at the greater height
[(6.67*10^-11)*25000] / ((8.9*10^6)^2)
that is.. G M / R ^2
equals 2.11*10^-20
subsitute that into MGH...
= mgh...
= 25000 * (2.11*10^-20) * (8.9*10^6)
gpe at greater height = 4.7 * 10^-9 Joules
the gravitational field strength at the Earth's surface is 9.8N/kg
so the GPE at surface of the Earth is
= M G H
= 25000 * (9.8*25) * (6.3*10^6)
equals ? something that doesn't look right?
this is converted to Kinetic Energy??... i think? oh god.. I am ready to get flamed badly
equals 2.11*10^-20
= mgh...
= M G H
mgh is only applicable for heights appreciably smaller than radius of the earth.
BJ
And please don't add a new question to someone else's thread- start your own thread.
