Help with Resistance Homework: Finding Sum to Infinity
  • Thread starter JJYEO325
  • Tags
    Resistance
In summary, the first term of a convergent geometric progression is 3 and the sum of the first five terms is twice the sum of the first ten terms. Using this information, we can set up an equality in r and solve for r. Then, using the infinite summation formula, we can find the sum to infinity of the progression.
JJYEO325
The first term of a convergent g.p is 3. The sum of the first five terms of the progression is twice the sum of the first ten terms. Find the sum to infinity of the progression.
S(5)= 3(r^5 -1)/4
S(10)=3(r^10 -1)/9
8^10-9r^5+1=0
Sum to infinity= 8.8
But the answer is 1.60
How did you get
[tex]S_5=\frac{3\left(r^5-1\right)}{4}[/tex]
It should be,
[tex]S_5=\frac{3\left(r^5-1\right)}{r-1}[/tex]
Firstly set up your summations correctly, and use the info that is given - mainly:
This should give you an equality in r, which can then be solved. Then use the infinite summation formula.
1. What is the purpose of calculating the sum to infinity in resistance homework?
The sum to infinity in resistance homework is used to determine the total resistance in a circuit with an infinite number of resistors in parallel or series. This helps in understanding the behavior of complex circuits and calculating the overall resistance.
2. How do I calculate the sum to infinity in resistance homework?
To calculate the sum to infinity, you will need to use the formula for an infinite geometric series: S = a / (1-r), where S is the sum, a is the first term, and r is the common ratio. In resistance homework, a and r represent the resistance values of the individual resistors.
3. What are the common mistakes made when finding the sum to infinity in resistance homework?
Some common mistakes when finding the sum to infinity in resistance homework include using the wrong formula, forgetting to convert resistance values to their reciprocals, or forgetting to include all resistors in the calculation.
4. Can I use the sum to infinity to calculate resistance in any circuit?
The sum to infinity can only be used to calculate resistance in circuits with an infinite number of resistors in parallel or series. It cannot be used for circuits with a finite number of resistors or those with more complex configurations.
5. How can I check my answer for the sum to infinity in resistance homework?
You can check your answer by using a calculator to calculate the sum and comparing it to your result. You can also double-check your calculations and make sure you have included all resistors in the circuit.
