Help With Self-Biases JFET Amplifier
  • Thread starter Thread starter fys iks!
    Amplifier
The discussion focuses on designing a JFET amplifier circuit that provides voltage gain, followed by a BJT for additional amplification. The main issue is that the JFET output waveform oscillates around a positive voltage rather than 0 V, while the BJT output oscillates around 0 V. Suggestions include using a coupling capacitor to remove the DC component from the JFET output and adjusting the resistor connected to the BJT base to ensure proper biasing. A 100uF capacitor was initially used, but it caused the BJT output to only show negative peaks. Participants recommend using smaller capacitors and adjusting the resistor value based on the collector voltage to achieve the desired output.
fys iks!
Hi,
I am designing a circuit where i first use a JFET transistor to a provide a voltage gain, the JFET is wired as a self bias. Following the JFET is a BJT transistor which i am using to provide a second amplification. I have an issue though with the output waveform of the JFET transistor. I am not sure why but the output waveform is an amplifier version of the input waveform, except it is also raised by a certain voltage so the sine wave oscillates about a positive voltage and not 0 V. The output of the BJT however oscillates about 0 V. How can i make the output of the JFET oscillate about 0 V?
Any help is appreciated.
fys iks! said:
Hi,
The output of a BJT amplifier (at the collector) or the JFET amplifier (at the drain) should be about half of the supply voltage with no input signal. This is because you want the output to be able to swing upwards for a negative going input signal and downwards for a positively going input signal.
Note that this means the output is actually an inverted version of the input.
Both outputs can have this DC component removed by passing the output through a coupling capacitor with a resistor to ground on the other side of it.
If you have a bipolar transistor with near zero voltage on the collector, then it is being driven to saturation by having too much DC voltage on its input.
So, you may need a coupling capacitor between the two stages.
ok that sort of worked. I added a 100uF capacitor then after the capacitor a 1k resistor to ground. In doing this the first output waveform had no more DC voltage, but this also messed up my second output of the BJT network. Now then output from the BJT is just 0 V with negative peaks but no positive peaks. So basically a sine wave that is just 0 wherever there should be a positive voltage.
OK. A bipolar transistor has to have base current and this is supplied by having a resistor connected to the base and to a source of positive voltage.
This is one way to do it:
The resistor shown as Rb would be something like 150 K ohms.
You can adjust it by measuring the voltage on the collector. If this is less than half the supply voltage, then the resistor Rb is too small. If the voltage at the collector is more than half the the supply voltage, then the resistor Rb is too big.
Capacitors of about 10 μF maximum would be used in circuits like this. 100 μF is a bit too big.
Could you post your circuit? It is very difficult to give advice about a circuit based on what we think it is.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
