Help with this Telescoping Series
Je m'appelle
Show that
\sum_{n=1}^{\infty} \frac{1}{(n+1)(n+2)} = 1
So as this is a telescoping series, I rewrote the general formula through partial fractions as
\sum_{n=1}^{\infty} \frac{1}{(n+1)} - \frac{1}{(n+2)} = 1
The first few terms will be
(\frac{1}{2} - \frac{1}{3}) + (\frac{1}{3} - \frac{1}{4}) + (\frac{1}{4} - \frac{1}{5}) + (\frac{1}{5} - \frac{1}{6}) + (\frac{1}{6} - \frac{1}{7}) + ... + (\frac{1}{(n+1)} - \frac{1}{(n+2)})
It can be seen then, that the first term \frac{1}{2} and the last term \frac{-1}{(n+2)} do not cancel, therefore, it turns out to be basically
\sum_{n=1}^{\infty} \frac{1}{(n+1)} - \frac{1}{(n+2)} = \lim_{n \rightarrow \infty} (\frac{1}{2} - \frac{1}{(n+2)}) = \frac{1}{2}
What am I doing wrong here? Is this telescoping series equal to 1 or 1/2? My textbook says 1 as I pointed out in the beginning of this thread, but I came up with 1/2, so I'd like to know if I'm doing something wrong or if I'm correct and the textbook has a typo.
Thanks in advance.
You haven't done anything wrong - the sum doesn't equal 1.
Hi Je m'appelle! :wink:
Your result looks correct to me. :smile:
The given answer would be for a ∑ starting at n = 0, not n = 1. :frown:
Yes, it seems then that it is a typo of either the sum being equal to 1/2 or n being equal to 0 heh instead of 1 and 1 respectively.
Thank you for your help statdad and tiny-tim :smile:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
