Help with understanding stress tensors
  • Thread starter Thread starter MaxManus
    Stress Tensors
The discussion focuses on understanding the components of the 3x3 stress tensor used in continuum mechanics. The normal stress in the 1-direction is represented by σ11, while σ12 indicates shear stress in the 1-2 plane. Each component σij of the stress tensor represents the force per unit area in the i-direction on a surface with a normal in the j-direction. When the indices are the same, it signifies normal stress, while different indices indicate shear stress. The clarification on Pn, Pnn, and Pnt relates to forces acting on normal and tangent surfaces, emphasizing their role in stress analysis.
MaxManus
I'm taking a continuum mechanics course and we use the 3*3 stress tensor a lot. The problem is that I do not understand what each component mean.
What does the tension(Pn normal(Pnn and tangent(Pnt tension mean, or just Pxy?
For a stress tensor \sigma, \sigma_{11} is the normal stress in the 1-direction and \sigma_{12} is the shear stress in the 1-2 plane. Does this answer your question?
The component \sigma_{ij} of the stress tensor \sigma is the force per unit area in the i-direction on a surface with normal in the j-direction. When the indices are the same, the force is normal to the surface so that it represents a pressure. When the direction of the first index is normal to that of the second, it represents a shear.
Thanks, does that mean that the Pn is the force per unit area in the i-direction on the normal surface and Pnn is the the normal force on the normal surface and Pnt is the the force in the normal direction on the tangent surface?
Pn = P dot n
pnn = P dot n dot n
Where P is the stress tensor and n is the normal.
