Help with velocity vs, time graph
To create a velocity vs. time graph for Tommy's car, start with a horizontal line at zero velocity while he waits at the traffic light. As he accelerates, draw a positive diagonal line representing an increase in velocity over time. Once he reaches the speed limit, depict a horizontal line at a constant positive velocity. When he decelerates for the red light, illustrate a downward slope until the velocity returns to zero. Finally, the graph should show a horizontal line at zero again while he stops at the light.
madeeeeee
Draw a velocity vs. Time graph Please I REALLY need HELP!?
7. Sketch a velocity versus time graph of Tommy in his car for the following situation. [5]
• He is waiting at a traffic light.
• He accelerates up to the speed limit.
• Travels at the speed limit for a while.
• Decelerates when he sees a red light.
• Stops at the light for a while.
There are no equations
I don't know how to draw this!
I need help
please!
Okay, so if he is waiting at a traffic light, his velocity should=0. Time is still passing, so its a straight line but it sits on top of the x-axis (y=0). When he accelerates, his velocity will raise over time, so that's a positive diagonal line. Now he is cruising at a constant velocity. That's a straight line at some positive value of y. When he decelerates, the line goes downwards (make a negative slope) and it will eventually hit zero, where it will just go along the x-axis again.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
