HELPCAN anyone explain the difference between an AC and DC motor?
AC motors are generally more powerful and suitable for high-voltage applications, while DC motors are favored in smaller devices due to their simplicity and high startup torque. DC motors, especially brushless types, are commonly used in radio-controlled models and electric aircraft, benefiting from pulse width modulation for speed control. In contrast, AC motors have become more versatile with advancements like inverter technology, but this can complicate smaller applications. Universal motors, which can operate on both AC and DC, combine the benefits of both motor types but have drawbacks like brush wear. Overall, the choice between AC and DC motors depends on the specific application and power requirements.
yujay
i was wondering y there still got some dc motors,coz ac motors more powerful...can anyone tell me y?
Here's are two links from the same web site:
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/motorac.html
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/motdc.html#c1
Those examples are a bit simplified and don't include brushless motors as shown on this web site:
http://www.oddparts.com/acsi/motortut.htm
They've also solved the low rpm issue with AC motors, since they are now optionally used in diesel electric locomotives.
http://www.railway-technical.com/diesel.html
I fly radio control models, mostly gliders, but have friends that fly electic powered aircraft. All of these use DC motors as far as I know. The cheap motors use brushes, and use pulse width modulation to control voltage which controls motor speed. The better motors are brushless, the coils are on the outside which is better for heat dissapation. The brushless motors need special speed controllers that sense and control the commutation of the motors. The stronger motors spin too fast for the large props they drive so they use gears to drive a prop. One new type of brushless motor has the outer coil as the moving part, and these are usually higher torque lower rpm motors, and don't require gearing.
Fascinating train site, Jeff. I've added it to my 'favourites'.
Yujay, remember also that on a smaller scale, inverter technology to convert DC battery current to AC is an unnecessary complication and expense. You wouldn't want it for something like a cordless drill.
AC motors can be built with more power since they have access to very large sources of power. 480V and 100A of current is already 100 times more power than what would completely drain a car battery in 1/2 hour.
AC motors do have some drawbacks though for small applications. So for a small hand drill with a cord that plugs into the wall, it has what's called a universal motor. Its actually a DC motor design that also happens to work on AC. It has the advantages of a DC motor with its high startup torque and maybe reversible direction, but also the disadvantage of brushes that wear out, and so on.
As Danger said, since a battery powered device only has DC to work with, it makes sense to have a motor that works with that source. It wouldn't make much sense to have to add circuitry and expense to convert to AC.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
