Thanks for that f95toli. The laser cutters I came across seem to have a pulse range of about 100 kHz–1 MHz (refer
http://www.spectra-physics.com/prod...t?cat=micromachining&subcat=femtosecond#specs), sometimes up to 2MHz. I originally was planning on controlling the pulse rate with a PLC but found out that the affordable ones cannot go as high as 1MHz. Instead I may need to be using a programmable function generator.
Last night I came across a study by the University of Tsukuba in Japan that seems to have proven atomic motion under pulsed light (refer
http://www.eurekalert.org/pub_releases/2016-02/uot-sro022216.php) - see attached press release.
From what I can understand, the pulsing induced a change in atomic position and rotation of the target compound. This correlates with another study in 2001 wherein pulsed laser light induces motion along the laser pulse propagation direction (refer
http://journals.aps.org/pra/abstract/10.1103/PhysRevA.64.013411).
There's 2 things I am trying to understand:
1. My intuition tells me that if the pulse frequency and light intensity are below those of laser cutting, the pulsed beam would excite the electrons and also cause motion of the atoms. If the alloy is eutectic (liquid), a gyroscopic motion in the plane of the light beam would be observed. But I have not found 'legible' scientific facts that confirm this… yet.
2. Moreover, I am wondering what radiation would be emitted from the gyring alloy. Again, I am assuming that the pulsed light (UV or other) would excite the electrons to higher shells and that a light particular to the alloy would be emitted. This particular light would be unrelated to the pulsed light, as the latter is only serving to cause excitation and motion, and instead, my intuition tells me that the new emitted light would be slowly pulsing with the motion of the alloy. Still only my intuition.
Does that shed any more light on the matter? - no pun intended
