High voltage high amperage supply
This discussion centers on the feasibility of building a high voltage, high amperage power supply using Tesla coils. The original poster proposes creating a Tesla coil capable of generating 300-500 amps at low voltage, while also utilizing a second coil for high voltage, low amperage. Participants highlight the impracticality of combining these two outputs effectively, emphasizing that such a setup would not yield a high amperage, high voltage supply due to inherent limitations in current and voltage characteristics. Additionally, safety concerns regarding arcing, equipment damage, and regulatory compliance are raised, indicating that the project requires substantial financial and technical resources.
  • Understanding of Tesla coil operation and design principles
  • Knowledge of electrical engineering concepts, particularly voltage and current relationships
  • Familiarity with high voltage safety protocols and equipment
  • Experience with power supply design and electrical isolation techniques
  • Research solid-state Tesla coil designs for sustained output
  • Study high voltage power supply design principles, focusing on current and voltage limitations
  • Explore high amperage power supply options, including industrial-grade equipment
  • Investigate safety measures and regulatory requirements for high voltage experiments
Electrical engineers, hobbyists interested in high voltage experiments, and individuals exploring advanced electromagnet applications will benefit from this discussion.
reddevil2576
Hello there i have an idea i want to try to build and i want to see what you think. I want to build a tesla coil that instead of making high voltage low amperage switch the coil sizes around so i have something that makes high amperage and low voltage say about 300-500 amps.
Then i want to take another tesla coil that creates high voltage and low amperage. What would happen if i make it so that the high voltage here jumps across through the air to the second coil that has the high amperage low voltage is this like putting batteries in series or parallel this isn't really either one. Would it do something different and combine the voltages and amperage's?
Even if it arc across, it only last nano seconds, what good does that do? Also when arcing like this, surface get burnt, making thunderous sound. When we test circuits at 10KV+ with high current capability, it was loud. Also you will never pass UL or CE emission test, you are going to freeze up all the computers in the surrounding. Also even if you can make it work, the power is limited by the power of the high voltage low current coil.You will find it very very hard to control the environment with your idea, humidity, ozone emission and all the above.
I would like to do solid state tesla coils for this so it doesn't last just nanoseconds. The only thing arcing across will be the high voltage low amperage though it will be arcing over to the high amperage supply. Will this combine them to make a high amperage high voltage power supply?
I don't think so, I don't think you can sustain an arc for that long and without destroying things. Also if you take a D cell of 1.5V of say 5A capability and put in series with a 9V small battery or only 0.5A capability, you don't get a 10.5V 5A capability power source. The current limit is limited by the 9V battery. You get a 10.5V 0.5A battery!
Not to mention you have to have some serious isolation power supply to power the circuit that is going to be jumped up. Tell me what you want first, I'll see whether there is any other way to get what you want.
Yeah but can you really say this is in series or in parallel all your doing is jumping the voltage across to the amperage. the grounds and powers aren't connected to be in parallel and the powerside isn't touching the ground on the otherside to be in series. i don't know though its just a thought I'm going to build sometime and see what happens. I need to build a very powerful electromagnet. I would like to use between 300-500 amps and about 50,000 volts for a power supply for this. and I am trying to build my own power supply within my money capabilities.
300A and 50KV?! You are talking about Mega Watt supply? This belong to company like Aidin Energy division I worked for back in late 70s that design the high voltage supply for the fusion experiment for Lawrance Livermore Lab. We needed to have special power line coming straight from PG&E! We had over 100 people and one division worth to work on this power supply alone! I think that was for a super magnet that suspend something up...I don't even know enough about the detail as we only get the contract to design the power supply and I was only a small engineer at the time to design the control system.
I hope you have very very strong financial backing!
actually i don't. i don't know if i need a power supply that big even. I'm just wanting to go big or go home. I have an invention that i want to build that's going to take very powerful electromagnets for it to work. I've been thinking about seeing if i can get funding to build my idea but i don't know where to begin. but if this idea worked you wouldn't need that deep of pockets to build it. i do appreciate the input you have given though.
I have a 250 amp DC welder. I am imagining connecting it to a 5 million volt tesla coil and DESTROYING both of them.
The rectifier diodes in the welder will go poof, all the insulation will arc over, and the initial pulse of 250 amps through the tesla coil will incinerate it too.Might make an interesting episode of Mythbusters, however . . .
Here is a more practical (from an engineering standpoint, if not from a financial one) idea :wire 500,000 Tesla coils in parallel, you will have the high voltage, and if one Tesla coil generates .001 amps, then you would have 500 amps if they were paralleled.
And please post a notice when you get ready to try this, I want to be as far away as possible.; )
Cold!:smile:
  • · Replies 31 ·
  • · Replies 49 ·
  • · Replies 36 ·
  • · Replies 25 ·
