Higher-Order DE Factoring: Can You Help Me Factor This Differential Equation?
  • Thread starter Thread starter optics.tech
    Factoring
optics.tech
Hi,
Can somebody please help me to factor the following DE?
2\frac{d^5y}{dx^5} -7\frac{d^4y}{dx^4} + 12\frac{d^3y}{dx^3} + 8\frac{d^2y}{dx^2} = 0
The auxiliary equation of above DE is
2m^5 - 7m^4 + 12m^3 + 8m^2 = 0
m^2(2m^3-7m^2 + 12m + 8) = 0
The equation of 2m^3-7m^2+12m+8 is cannot be factored in any form, at least after I try for several times.
Thanks in advance
That polynomial can certainly be factorized. You just need to look a little harder, or try some basic root finding
Hi Scottie,
Thanks in advance.
Since the degree of polynomial is > 2 then to find the factor is “by division”.
I’ve try that way but there is no solution.
Do you mean that “basic root finding” is\frac{-b\pm\sqrt{b^2-4ac}}{2a}?
If so, since it’s only can be used for 2-degree polynomial, how to use that formula in 3 degree of polynomial equation?
Thank you very much
Just plot
with a plotting hand calculator or computer plotting routine or by hand calculation. You will see a root, then check you have an exact one.
Note you have already factored the equations somewhat; that gives you some solution already which will later enter into the general solution.
The "rational root theorem" says that the only possible rational roots must have denominator divisible by 2 (coefficient of x3) and numerator a factor of 8. That is, the only possible rational roots are \pm 1/2, \pm1, \pm2, \pm4, or \pm8. Since you can get reasonable factoring only with rational roots, try those and see if any are roots.
Graphing 2m3-7m2+12m+8 reveals that \frac{-1}{2} is a root.
Using polynomial long division by (m+\frac{1}{2}) yields this:
(m+\frac{1}{2})(2m2-8m+16)=2m3-7m2+12m+8
See if you can finish from here.
