Higher Specific Heat Capacity: Explained
The discussion centers on the concept of specific heat capacity, specifically comparing two objects, A and B, where A has a higher specific heat capacity than B. It is established that when both objects receive the same amount of thermal energy, the temperature increase in A is lower due to its higher specific heat capacity. The First Law of Thermodynamics is referenced to explain that the increase in internal energy results from heat transfer and work done, indicating that energy conservation leads to a portion of thermal energy being stored as potential energy rather than solely as kinetic energy. The conversation concludes that higher specific heat capacity may result from stronger intermolecular forces or additional molecular degrees of freedom, which store energy in forms other than translational kinetic energy.
  • Understanding of specific heat capacity
  • Familiarity with the First Law of Thermodynamics
  • Knowledge of kinetic and potential energy concepts
  • Basic grasp of molecular motion and degrees of freedom
  • Research the relationship between specific heat capacity and intermolecular forces
  • Explore the concept of degrees of freedom in molecular physics
  • Learn about energy conservation in thermodynamic systems
  • Investigate the differences between translational, rotational, and vibrational kinetic energy
Students studying thermodynamics, physicists interested in energy transfer, and educators teaching concepts of heat capacity and energy conservation.
Yh Hoo
Now consider two objects,A and B. A has a higher specific heat capacity that B. When both object is subjected to same amount of thermal or heat energy, rise in temperature in A is lower as our common reason(A has a higher specific heat capacity)
But what stated by First law of thermodynamics that Increase in internal energy is caused by heat energy transfer to in and work done on it. since temperature is a measure of average kinetic energy of particles in a system, it means perticles in A has a greater amount of kinetic energy than B. Meanwhile , energy should be conserved, so it means portion
heat energy flow to A and is stored as kinetic energy of particles is lower than B.
NOW, WHERE DOES THE REST PORTION OF THE THERMAL ENERGY FLOW TO A converted to? the electrical potential energy(another component of internal energy) of the particles in A ?
if so that means object with high specific heat capacity has a lower tendency to store the thermal energy received in the form kinetic energy of particles?
can somebody explain this to me? or correct me if i am wrong. Thanks a lot.
Science news on Phys.org
Temperature is the measure of only one kind of kinetic energy: translational kinetic energy (energy due to the motion of the centre of mass of the molecules). Rotational and vibrational kinetic energies do not directly affect temperature.
it means particles in A has a greater amount of kinetic energy than B. Meanwhile , energy should be conserved, so it means portion
Your question is a good one. There are two aspects to this. Higher heat capacity could be due to stronger forces between molecules (so some energy is stored as potential energy). It could also be due to additional degrees of freedom of the molecules (some energy stored as vibrational or rotational energy of molecules).
AM
wow thanks a lot! it is sufficient for me already as a pre u student.
  • · Replies 28 ·
  • · Replies 26 ·
