Is A always equal to zero if it is perpendicular to every vector X?
In summary: I can't think of it yet.ThanksIn summary, we are trying to show that if vector A is perpendicular to every vector X, then A must be equal to the zero vector. Using the trigonometric definition of the dot product, we can see that the dot product of A and X must equal zero for every vector X. This means that the magnitude of A times the magnitude of X times the cosine of the angle between them must equal zero. If the angle between A and X is 90 degrees, then the cosine will also be zero. Therefore, the only way for A to be perpendicular to every vector is if its magnitude is equal to zero, making it the zero vector.
Jbreezy
582
Let A be a vector perpendicular to every vector X. Show that A = O Edit: it is O not 0. (OH not zero) ha
So, we know if A and X are perpendicular then A(dot)X = 0
I see no reason why A would have to be equal to 0.
Could X (not equal) 0? Could it be both?
Above is my attempt. I get a hint please?
Think about the trigonometric definition of the dot product.
You might start by telling us what vector space your vectors are from. Is it ##{\mathbb R}^n##? What happens if you dot A with the standard basis vectors?
If a vector A is perpendicular to EVERY vector, it must be perpendicular to itself. So?
... assuming A is in the same space as X.
X could be a set of vectors lying in a plane.
But I agree - they key to this is to realize that that A must be perpendicular to EVERY vector.
I wrote the questions exactly as is. Doesn't say anything about the vector space. If I dot A with the standard basis vectors then...I'm not sure because all that I'm told is that A is perpendicular to X I do not know anything else.
How can a vector be perpendicular to itself?
Jbreezy said:
I wrote the questions exactly as is. Doesn't say anything about the vector space. If I dot A with the standard vectors then...I'm not sure because all that I'm told is that A is perpendicular to X I do not know anything else.
You are told that A is perpendicular to every vector. Not just some vector.
There is only one way, and it proves your result.
|A||X|cos(theta) = A (dot) B
Is the trigonometric definition.
If A is perpendicular to all vectors, it is perpendicular to itself. All vectors means all vectors, A is a vector, therefore A is perpendicular to A. Therefore
|A||X|cos(theta) = 0
Even whenever X = A.
What is the angle between X and A if X=A?
How can this equation always be 0 (perpendicular to any vector) if I allow one magnitude and theta to vary freely?
Only if A = 0. But wouldn't theta not vary freely if you are told it is perpindicular then the angle must always be 90 degree.
So why do you say theta varies freely. It would seem to me that X would vary and theta would always be 90.
How about this...can you just say ..The only way that A can be perpindicular to it's self is if it is the 0 vector?
No.
Two vectors are perpendicular if and only if their dot product vanishes. That is the definition. If I tell you that two vectors are perpendicular, then you can tell me that their dot product vanishes, and that is all. The dot product of O (dot) X = 0 for any X, it doesn't matter what I call the angle between O and X, nor can I say what it is (because it is arbitrary).
That two perpendicular nonzero vectors have an angle of 90* is a direct corollary to that definition. It has no effect on this proof, because we aren't explicitly talking about nonzero vectors.
If you do not let theta vary freely then you are not considering every vector. The theorem you are proving states that X is perpendicular to every vector, not just ones that make an angle of 90* with it.
You have to show why that assertion is true.
0?
So
So just from the trig defination like you say the only way that it can be 0 is if A is 0 because X and theta vary.
I don't know how to show that the only way to be perpindiuclar to it's self is if it is 0.
Your proof is mostly words like stating conditons not really like showing it. (you are though if you get what I mean)
So I suppose that saying A can only be perpindicular to itself if it is the zero vector would be sort of the same. I can't think of it yet.
Thanks
Jbreezy said:
0?
So
Thanks
What's your definition of 'dot product'?
If A is perpendicular to B, then
|A||B|cos(theta) = 0
Consider the case where A = B.If I say anything else, I've done it for you completely.
X dot A = |X||A|cos(theta)
Yes, so now write that for X (dot) X and show, algebraically, that |X| is 0 if the dot product is 0.
Is just
A dot A = |A||A|cos(theta)
A dot A = |A||A|cos(0)
cos(0) = 1 so A must be 0
I don't like this
You need to set the equation equal to 0.
|A||A|cos(0)=0
|A|^2 =0
|A|=0
What do you mean you don't like it? It concisely proves the theorem by literally, simplifying and dividing once. Itdoesn't get much cleaner than that.
"Show that if A is perpendicular to all vectors, A is the 0 vector"
Proof:
If A is perpendicular to all vectors, then it must be perpendicular to itself, thus
A(dot)A= 0
|A||A|cos(0) = 0
|A|^2 = 0
|A|=0
Since the magnitude of A is 0, A is the zero vector.
That's all there is to it.
What is wrong iwth how I said it?
You didn't set the equation equal to 0, all you said was that A(dot)A = |A||A| and then asserted that A was 0. Reading that, no one would know what you were talking about. You can't solve for A in the equation A(dot)A = |A||A| because it is tautological.
Yes they would because I said cos(0) =1 so if it is 1 then A must be 0 for it to be 0
Thanks,
Thanks,
No, they wouldn't, because you never mentioned that the dot product is equal to 0 in the first place.
Jbreezy said:
Is just
I don't like this
No where did you say that A dot A is 0. You need to say that the equation is equal to 0 in order to solve for A.
What you wrote doesn't say anything about A. You said it must be O, but based on what you wrote, it doesn't have to be O. A dot A = |A||A|cos(0) is true for any vector A, even one that is not O, and that is what you wrote.
A dot A = |A||A|cos(0) = 0
Is only true for A = O, so that is what you must use. Without setting it equal to 0, you aren't saying anything.
Opps.
Thanks
1. How do you prove the dot product hint?
The dot product hint can be proven by using the properties of the dot product, such as distributivity and commutativity, along with the definition of the dot product. By manipulating the equations and substituting in values, you can arrive at the desired proof.
2. What is the purpose of the dot product hint?
The dot product hint is used to provide guidance and direction in solving complex problems involving the dot product. It can help simplify the problem and make it easier to understand and solve.
3. How does the dot product hint relate to vector operations?
The dot product hint is directly related to vector operations because it involves the multiplication of two vectors and the addition of their products. The dot product is often used in vector operations to determine the angle between two vectors or the length of a vector in a specific direction.
4. Can the dot product hint be used in other mathematical fields?
Yes, the dot product hint can be applied in other mathematical fields such as linear algebra, calculus, and physics. It is a fundamental concept in mathematics and can be used to solve a variety of problems in different fields.
5. Is the dot product hint a proven theorem?
No, the dot product hint is not a proven theorem. It is simply a hint or a suggestion on how to approach and solve a problem involving the dot product. The proof of the dot product itself is a proven theorem, but the hint is just a helpful tool.
  • Linear and Abstract Algebra
