Homework: Finding an antiderivative
twinebiscuit
dy/dx = y(1-y)
dx = dy(y(1-y))?
What do you know about separation of variables ?
that you can separate them if there is an x and a y on the right side of the equation and they are multiplying
Alright, so can you separate x and y in your equation ?
I don't think so because there is no x on the right side it's only y?
Alright, then, you must reread your notes, because the equation you posted is separable, as it's a simpler case of the general
\frac{dy}{dx} = X(x)Y(y)
In your case, X(x)=1, so the variables can be separated.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
