Homogenous PDE with separation of variables
spaceknight
Sorry don't know how to use the partial symbol, bear with me
partial u wrt t=2*(2nd partial u wrt x)
Boundary conditions:
partial u wrt x (0,t)=partial u wrt x (1,t)=0
Initial conditions
u(x,0)=x(1-x)
I get an answer that is different than the solution manual, but I am convinced the solution manual is wrong, so I would just like it if anyone had the spare time to verify the solution for me. I do have a few minor questions though.
1. When solving for the eigenvalues, is n=0,1,2,3... or does n=1,2,3...? I ask this because I get 0 as an eigenvalue when doing the case for lambda=0, but technically this woulda already shown itself when I did the other case when I got the "real" eigenvalues because it was to solve sqrt(-lambda)=npi, so if n=0 that would have already been taken care of.
I get F(x)=Cncosnpix and G(t)= e^(-2pi^2n^2t) When I solve the Fourier series I used L=1 and got ao=-1/3 and an = (4(-1)^n) )/ (pi^2n^2)
So the equation you want to solve is:
<br /> \frac{\partial u}{\partial t}=2\frac{\partial^{2}u}{\partial x^{2}}<br />
with
<br /> \frac{\partial u}{\partial x}(t,0)=\frac{\partial u}{\partial x}(t,1)=0<br />
with initial condition u(0,x)=x(1-x)?
What are your steps?
Yeah that's correct.
As for my steps, I just followed normal procedure of separation of variables so
assume solution is u(x,t)=F(x)G(t)
So G'/(2G)=F''/F=λ and my 2 ODEs are:
1. G'-2Gλ=0
2. F''-Fλ=0
Then I solve for F using the three cases, λ<0, λ=0, λ>0 and the boundary values F'(0)=F'(1)=0. The only case that is non trivial is the λ<0 case which is when I get my λn=-n^2pi^2 and my Fn=Ccos(npix). I then plug in λn back into the other ODE to solve for G and I get G=e^(-2pi^2n^2t), and then I take the infinite sum and make it equal to the initial conditions which makes it a Fourier series representation. Then I apply the integration formulas to solve for the coefficients.
Going back to your questions you already took care of \lambda =0, so you can just have n=1,2,3...
Was that all the questions you had?
Mat
Well, when I take the infinite series do I start from n=0 then because lambda=0 is included? Cause then I take the first term and I get the ao constant, which I'm assuming is suppose to happen but I just wanted to clarify.
And I was kinda hoping if someone would solve it so I can compare my answers because the solution manual has another answer that I have no idea how they got and there are no steps.
I think you can say that \lambda &lt;0 straight away as otherwise the solution will grow exponentially with t. So write \lambda =-\mu^{2} and you get the two solutions:
<br /> G=Ae^{-2\mu^{2}t},\quad F=B\cos\mu x+C\sin\mu x<br />
As this is just one particular solution and there are an infinite many so write:
<br /> u=\sum_{n=0}^{\infty}A_{n}e^{-2\mu_{n}^{2}t}(B_{n}\cos\mu_{n} x+C_{n}\sin\mu_{n} x)<br />
Was that what you did?
Yeah except there's no sin
I think you should check again the case where λ = 0. I think you will find that a constant works. And that's what you would expect given that you will be expanding a function in a cosine series.
I know lambda=0 does work, but since its a constant doesn't it just merge with the coefficient in F=Ccos(npix) if I start n=0,1,2,3...
Yes. It does give you the constant term of the FS.
