Homomorphisms and isomorphisms
  • Thread starter Thread starter happyg1
    Homomorphisms
happyg1
Letv_1,v_2,...v_n be a basis of V and let w_1,w_2,...w_n be any n elements in V. Define T on V by
(\lambda_1 v_1+\lambda_2 v_1+...+\lambda_n v_n)T=\lambda_1w_1+...\lambda_n w_n.
a)Show that R is a homomorphism of V into itself.
b)When is T an isomorphism?
An isomorphism is a 1-1 mapping.
I think I have part a) done, although It makes more sense to me to prove that T is a Hom, not R...not sure where the R came from.
For part b, I am thinking that since the v_i are a basis that the Iso would be true if the w's were a basis also?
IK know that an iso occurs when the Kernel is zero..but I'm still kinda confused here.
Any hints or advice will be appreciated.
Thanks,
CC
Obviously, in order for T to be an iso, w_i must be a basis - the image lies in the span of the w_i, and that can only be all of V if they are a basis. That says T an iso implies w_i a basis. What about the converse?
Now, suppose that v is sent to zero by T, i.e. vT=0. Then what does that say about the linear combination of the w_i that v is sent to?
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
