Hooke's Law and suspended objects
  • Thread starter Thread starter annatar
    Hooke's law Law
In the discussion on Hooke's Law and suspended objects, the problem involves a mass suspended from a spring and the resulting stretch due to different mass configurations. The first scenario has a mass m causing a stretch of 0.1m, while the second scenario involves two masses of m/2, leading to a total stretch of 0.05m. The tension in the spring is crucial; in the first case, it equals mg, while in the second case, it equals mg/2 for each mass. The spring's stretch is proportional to the tension, which is halved in the second scenario. Understanding that both masses contribute to the tension clarifies the mechanics of the spring's behavior.
annatar
A body of mass (m) is suspended from a spring with spring constant k in configuration (a) and the spring is stretched 0.1m. If two identical bodies of mass (m/2) are suspended from a spring with the same spring constant k in configuration (b), how much will the spring stretch? Explain your answer.
F = -kx (Hooke's Law)
Since in the first case the mass is at rest,
by mg - k(0.1) = 0, i calculated that k = 10mg
In the second case, since the bodies suspended have a mass of (m\div2), their weight is halved too. Therefore the spring will stretch for 0.1\div2 = 0.05m on each side.
i.e. It stretches for 0.1m (0.05m each on left and right)
However, according to the solution, the answer is 0.05m.
It is also stated that "if you have problems, substitute one of the two masses with a fixed hook; does the spring change its length?"
What difference does that make?
Attached is the diagram describing the setup
Hint: The stretch of the spring is proportional to the tension. What's the tension in the spring in each scenario?
Tension in the spring?
Case 1:
T = mg
Case 2:
T = mg/2
But it is pulled from both sides!
Do both blocks of objects with mass (m/2) cause the spring to stretch?
This is getting confusing...
Case 1:
T = mg
Case 2:
T = mg/2
Good.
It better be! Hint: The spring is being pulled from both sides in both scenarios.
Sure. You need both blocks pulling to stretch the spring. Remove one, and the spring will go flying as the mass falls.
So...
In case 2:
One of the masses is responsible for preventing the spring from flying out,
while the other one causes the stretch?
Therefore stretch length = 0.1/2 m = 0.05 m (since weight causing the stretch is halved)
annatar said:
So...
In case 2:
Don't think of it that way. To stretch a (massless) spring you must pull it from both ends with the same force--that force equals the tension in the spring.
In case 1, the ceiling pulls up on one end while the mass pulls down on the other; both ends of the spring are pulled with a force equal to mg. The tension in the spring equals mg; it stretches accordingly.
In case 2, each end is pulled with a force equal to mg/2. The tension in the spring equals mg/2; it stretches accordingly.
