Hot Air Rotation: Can Heat Create Constant Motion?
  • Thread starter Thread starter shaden
    Air Hot Rotation
A closed container with heat applied to the bottom half and insulation or reflection on the top half can create a constant rotation of air. The heated air rises, cools as it reaches the top, and then descends, establishing a continuous cycle. This concept illustrates how temperature differences can drive air movement. The discussion emphasizes the potential for sustained motion through thermal dynamics. Such a system could have implications for understanding heat transfer and airflow in various applications.
shaden
Imagine a closed container (full of air) that allowed sunlight or other heat inside the bottom half, but block or reflected this heat on the top half.
Would this create a consant rotation of air being heated and going up, then cooling off and falling back down?
Sure would.
what's means
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
